F1R on a truck
Old Feb 19, 2010 | 01:47 AM
  #41
SLO TRUCK's Avatar
Jason you have more than enough motor to entertain any FI application. A wicked Pro charger would be cool, but twins running a 10.xx in an ECSB in full street trim is pretty sick too.
Old Mar 7, 2010 | 04:27 PM
  #42
Casey2323's Avatar
What is it that you guys like so much about the prochargers? Just thinking here, not bashing, it makes tq slower than a turbo and has more parasitic drag than a turbo so why go with a procharger? It seems the belt slip problems of old are gone with the new generation of brackets etc so that helps prochargers case to become more widely used. Back in the day everyone was throwing belts when using the bigger headunits not to mention if you chopped the throttle but with the super pulley that doesnt matter either. So why would someone willing to run a little higher stall go with a procharger over a turbo?
Prochargers are the **** !!... But there is less info and almost a worse rap then rear mounts..... but fact its there are 2-3 people that have been in the 10s with out of the box kits.. And thats 10s with small cubic inch heads/cam motors .. no huge exotic parts... no hastle with belts anymore.. the bad wrap is from there "kit" having small POS BOV's that would hang up and cause problems... all of that is gone..... I like them alot and been working with two of them myself....... Results to come soon
Old Mar 9, 2010 | 11:55 AM
  #43
noonzor's Avatar
siiiiiiiiick, those are some monster turbos
Old Mar 9, 2010 | 12:23 PM
  #44
BlownChevySS's Avatar
If you're talking about the ones on page 4, they are centrifugal superchargers, not turbos.
Badass setup for sure
Old Mar 9, 2010 | 12:32 PM
  #45
Wilde Racing's Avatar
How do I change this text
Iv'e driven a couple procharged vehicles, and the power delivery is SUPER SMOOTH, Works well for vettes that do more than just go strait.
Old Mar 9, 2010 | 01:22 PM
  #46
noonzor's Avatar
wow, my bad. never seen superchargers mounted like that.... thats awesome!!
Old Mar 9, 2010 | 04:42 PM
  #47
You can mount turbos and centrifugal superchargers anywhere you have space as long as you do all the plumbing and make brackets. However, roots blowers have to go on top.
Old Mar 9, 2010 | 04:55 PM
  #48
schino's Avatar
roots can go on the front also or mounted remote. first roots on a V8 was mounted like that F4. Potvin style. but yeah most common is on the top
Old Mar 9, 2010 | 05:18 PM
  #49
True. It all depends on the setup. But ideally, they sit on top. Thanks for clearing that up.
Old Mar 10, 2010 | 10:44 PM
  #50
Sierra1320's Avatar
Now I'm assuming that the procharger LSX Transplant kit that he's using will only fit on an 6.0 block and not a 4.8/5.3 block correct?
