Exhaust + STS
Old Apr 9, 2008 | 01:30 PM
ducky's Avatar
Default Exhaust + STS
Just a tad bit of background on the truck before I ask the questions that I have..
01 5.3
STS gt-67
Nelson SD tune
Stage 1 meth kit
FMIC
5lbs..(8lbs in a few days)
stock internals
FLT 65e
3.42 gears
eaton posi
Exhaust consists of:
Pacesetter longtubes
ORY 3"
- turbo is mounted about a foot and a half right past the cab. The pipe looks like it goes from 3" down to 2.5".
- exhaust exit on the turbo is just a foot long down pipe.
Question is:
How much is this exhaust setup hurting/helping to build boost. I tried searching for longtubes and STS but I couldnt really come up with anything. How much faster would it build boost with stock manifolds and a y pipe? I dont plan on putting a muffler on it to quiet it down or anything of the sort because I love the sound.. Any input on this would be great.
thanks,
david
Old Apr 9, 2008 | 01:36 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Go to stock manifolds and an ORY and wrap the exhaust will make a big difference from what everyone has posted.
Old Apr 9, 2008 | 01:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
it would spool better and load up faster with the exhaust wrapped.... Stock manifolds are better than long tubes in this case. IMO... heavier material = more heat retention.
Old Apr 9, 2008 | 01:38 PM
ducky's Avatar
I have yet to look at a stock y pipe off of a truck. But would I need to get one made to go all the way down to the turbo? How big in diameter should the y pipe be?
Old Apr 9, 2008 | 01:41 PM
Hunt&Fisherator
the STS was meant to bolt on to a completely stock truck... manifolds, a stock Y pipe and intermediate pipe would be all you'd need I believe... no need to change size with that turbo and cubic inches IMO...
Old Apr 9, 2008 | 01:43 PM
1slow01Z71's Avatar
David if you want to swing by my place you can see my stock y pipe. I would just order a jegs ORY and take it to an exhaust shop and get them to mate it to the STS kit. I just so happen to have the header wrap and spray you need to wrap your exhaust. I bought it to do my STS when I had it and forgot about it sitting int he corner of the garage until right now.
Old Apr 9, 2008 | 01:53 PM
ducky's Avatar
sweet how much you wanna sell that wrap and spray for? I gotta find the stupid manifolds I had laying around my house. I think I lost them. When you gonna be home today?
Old Apr 9, 2008 | 02:31 PM
1slow01Z71's Avatar
Ill be home after 6
Old Apr 9, 2008 | 06:17 PM
quicksilverado's Avatar
Don't use an aftermarket y-pipe. Been there done that. The metal they use is thin and they do not seal worth a damn. Get a stock y-pipe and gut the cats. It will seal and the metal is much thicker so it will retain the heat better.
Old Apr 9, 2008 | 06:38 PM
TG02Z71's Avatar
Wrapping the pipes gets the whole system up to operating temps quicker and keeps them there when not in the boost or idling for a long time. it does help, noticeably. I had it with and without and know first hand.
