Exhaust questions for turbo build
Old Feb 13, 2011 | 01:40 PM
Hemitruck04's Avatar
Default Exhaust questions for turbo build
Ok Im working on my project and I just have a few questions about exhaust piping, maifolds, flow and so on. My plan is to run a log type manifold but my concerns are if it will flow OUT and into the turbo. My idea is on my V8 is to get some header flanges, take 2" primaries and go up with the front 3 of them into a 3" pipe, the last exhaust port towards the back of the engine will feed into the back side of the 3" pipe. The 3" pipe will then 90* to the front of the engine then each side will meet in the middle and Y into my turbo Flange. So will this be a good method for running my pipes or will I encounter a flow issue? This truck Is a daily driver so I want to be able to drive at low boost levels and No boost at times as well, so I set it up with a 3:55 rear end and am using a Large frame Garrett GT4708 80mm with T6 1.32 AR I may change my AR to a .96 Only reason for hte 1.32 is it came with it. Now this turbo weighs about 50lbs will my manifolds be suitable to hold such a unit or should I encorporate a mounting system, my header flanges have 8 bolts and are 3/8th thick steel
Old Feb 14, 2011 | 12:27 PM
Noone?
Old Feb 14, 2011 | 06:12 PM
Bluchevypick's Avatar
I dont see why that wouldnt work. I would recommend making a bracket to help support that heavy turbo though.
Old Feb 14, 2011 | 07:04 PM
smokeshow's Avatar
Mod with training wheels
Kyle's kits are made out of schedule 40...I'd like to see a turbo break that lol. What do you mean you are concerned about flow problems? Where else would the exhaust gas go besides the turbo?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
kyle's v
Oct 4, 2015 12:37 PM
USMCvet0311
Aug 14, 2015 10:28 PM
lxcoupe
14
Jul 9, 2015 09:15 PM
Cowboy17
Jul 9, 2015 06:18 PM
