exhaust housing clearing ac line
Old Jan 9, 2013 | 11:55 PM
UnVmy5.3's Avatar
Default exhaust housing clearing ac line
Anyone running around a 105 ar on the exhaust Side with a log manifold running into issues with the AC lines?
Old Jan 9, 2013 | 11:58 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I've read that you need to carefully bend that line over and out of the way. Might be a good idea to wrap it also.
Old Jan 10, 2013 | 12:05 AM
UnVmy5.3's Avatar
I've read that aswell but didn't know If it was done with a larger ar
Old Jan 10, 2013 | 07:19 AM
GMCtrk's Avatar
Just grab the hose and pull it away. The aluminum bends easily.
Old Jan 10, 2013 | 07:25 AM
Choda's Avatar
I bent mine with my little 70mm and wrapped it. it still blew up. I ended up getting a custom line made and re filled the system for 400 bucks.... ouch
Old Jan 10, 2013 | 07:54 AM
TrickTurbo's Avatar
Truck Sponsor
You need as much room as possible. 1" would be a min.
You can also move the line at the compressor to gain more room.
Old Jan 10, 2013 | 08:47 AM
GMCtrk's Avatar
Did you have a turbo blanket?
Old Jan 10, 2013 | 09:52 AM
9 Second Club
After my A/C line exploded I rerouted it to give more clearance around the exhaust housing. It cleared no problem on a small turbo, but when I switched to an 80mm with 1.10A/R it was too close and didn't last long. It would have been cheaper and easier to just pull the system down, and move the line then recharge. If yours is too close and won't bend enough to provide clearance I highly suggest being proactive with a fix.
Old Jan 10, 2013 | 10:05 AM
Choda's Avatar
I agree. I only had about half inch
Yes and wrapped dp and wrapped ac line. The dp was the closest part not the housing itself.
Old Jan 10, 2013 | 10:34 AM
lglowe's Avatar
I've had no problem with a 1.25 Borg Warner.
