exhaust gas temp sensor with sts?
where are you guys puting the egt sensors on the sts setups? I was thinking right behind the turbo! Is that right? What kind of temp's are you seeing? what is concidered lean and rich? I think it depends on location right?
EGT sensor, should be as close to the motor as possible. This is so you can get an accurate read as to what the motor is doing. The further down stream you put the sensor, the more variables you add like cats, mufflers, and turbo to loose heat from.
ZO6Ted
Aug 12, 2015 07:50 PM
V-seriesTech
Jul 28, 2015 12:31 PM
Nimoryan
Jul 5, 2015 03:50 PM
