exhaust gas temp sensor with sts?
Old Apr 21, 2006 | 06:59 AM
TURBO8's Avatar
Default exhaust gas temp sensor with sts?
where are you guys puting the egt sensors on the sts setups? I was thinking right behind the turbo! Is that right? What kind of temp's are you seeing? what is concidered lean and rich? I think it depends on location right?
Old Apr 21, 2006 | 08:46 AM
kenihemi's Avatar
I have a bung welded just before the cat on one side.
Runs between 850 and 1300 depending on the load.
Old Apr 22, 2006 | 12:56 PM
kbracing96's Avatar
EGT sensor, should be as close to the motor as possible. This is so you can get an accurate read as to what the motor is doing. The further down stream you put the sensor, the more variables you add like cats, mufflers, and turbo to loose heat from.
Old Apr 22, 2006 | 02:03 PM
Scott Mills's Avatar
I placed mine about 6 inches down from the collector. Without the STS kit I am getting between 1000 to 1300 depending on the load. With my STS kit I was getting 1300 to 1600.
ullose272
Aug 5, 2016 02:05 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
V-seriesTech
Jul 28, 2015 12:31 PM
Nimoryan
Jul 5, 2015 03:50 PM
