egt temps...what good/bad
Old Apr 14, 2009 | 09:36 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by SincalT/A
If the vehicles has cats yes the egt's will be high in rich conditions.Most likely killing the cat.
No cats no burn.Unless timing is drastically off.
I have seen stupid hi egts on my SBC blower set up. Pipes glowing red and having 30 degrees of timing in the engine. Fuel can burn in the pipe causing a higher then normally egt reading. I have personally pulled a plug after seeing a 1500 egt reading. Plug was black and sutty looking. Change jetting and the carb set up, egts came down and plugs started cleaning up.
You only have so much time to burn the fuel you have before that flame has to be moved into the exhaust.
Old Apr 14, 2009 | 09:48 PM
SincalT/A's Avatar
Your right I took alittle time to think bout what I said.
I also am not sure if what we see in those condition is an actual burn or heat left over from the combustion process.
Old Apr 15, 2009 | 11:39 AM
TURBHOE's Avatar
the probe is about 2-3" from the port on the #7 cyl. 1200-1300 was under load going up hill mostly. i'll explain more later and load some logs.
Old Apr 15, 2009 | 12:49 PM
thunder550's Avatar
High on diesel fumes
Sounds about normal to me. I was usually around 1200 or so just cruising on the highway around 70mph. Cruising down a surface street at 45-50 they would be much cooler, maybe in the 900-1000 range. Highest I saw when I was paying attention was about 1550 under boost. That made me a little nervous but didn't hurt anything.
Old Apr 15, 2009 | 02:34 PM
TURBHOE's Avatar
i haven't been that high in egt's since the meth install. i seen 1800 once down the track. that was no good.
it had no KR while in boost. but while not in boost it would get some. i tried taking the timing away but it still got KR. either way. the fuel was good while not in boost trims were low. -3 or so. the fuel while boosted was around 10.5-11.5:1 and 17* timing. here is the latest log.
Old Apr 15, 2009 | 05:46 PM
silver-mod-o's Avatar
Hunt&Fisherator
mine normally cruises 1050-1100 and gets up around 1375ish in longer periods of boost/load
Old Apr 23, 2009 | 10:02 AM
mine are spot on to thunder550's readings
thunder550
Oct 8, 2015 04:53 PM
turbo6c3
Oct 5, 2015 06:11 PM
kbracing96
Sep 21, 2007 11:16 PM
Fogle07
Dec 7, 2005 12:20 PM
ranwalk
Dec 3, 2003 11:30 PM
