EFILive tune for Kenne Bell
Old Aug 6, 2007 | 01:10 PM
Gordy M's Avatar
Default EFILive tune for Kenne Bell
I am getting ready to install my old style Kenne Bell supercharger on my 2004 Escalade ESV. Does anyone have a KB tune I can use as a start platform. Preferably a 6.0/drive by wire/towing.
Primary use is hauling enclosed 24' trailer and getting out of other peoples way.
Old Aug 6, 2007 | 03:10 PM
03sierraslt's Avatar
Sorry not for EFI Live. I can give you pointers along the way if you need them. Just let me know.
Old Aug 6, 2007 | 07:51 PM
Stoichiometric's Avatar
Here is the superchips tune that came with my Radix. It is 6.0L, 4l80e drive by wire straight out of the handheld. Look through the injector scale(make sure it matches for flow rate and manifold ref. fuel pressure) and trans pressures(maxxed out by superchips) before you flash your truck. There is not much changed in the tune besides PE throttle enable %, PE vs. RPM and shift pressures.
File Type: tun
Old Aug 6, 2007 | 08:03 PM
Just remember the tranny file for a 80e is much different then one for a 65E like he has. I actually never seen a KB tune file, I never used one.....
You are going to be running 43lb injectors correct?
Old Aug 6, 2007 | 08:12 PM
I mentioned about the injectors because the superchips tune has them scaled incorrectly for my truck, I do not have a manifold ref. FPR.
Old Aug 6, 2007 | 08:30 PM
Gotcha
Old Aug 7, 2007 | 07:56 AM
Gordy M's Avatar
Thanks for the tune. While the trans is not the same the other values should help me start. I am currently working on the trans making logs while hauling the trailer loaded with the car. Everything is fine in NA form except the OD lockup. On some days it stays locked and other days it starts to rev up before the 4-3 shift.
Regarding the injectors I do have the 8.1 Marine injectors from KB.
03sierraslt: As I get closer to finalizing my tune I will probably contact you for more info, thanks for the help.
Old Aug 7, 2007 | 01:57 PM
No problem man. Just let me know
TXsilverado
Nov 26, 2015 10:54 AM
TXsilverado
Sep 26, 2015 12:48 AM
JFortner5
Aug 20, 2015 06:13 PM
