Ebay Roush TVS1900 installed
Old Mar 19, 2010 | 04:28 AM
  #151
skipperdaddy's Avatar
Do u know what psi this thing is putting out?
Old Mar 20, 2010 | 05:36 PM
  #152
DOA's Avatar
DOA
I've heard 9psi. Are stock head gaskets ok at that pressure?
Old Mar 20, 2010 | 06:21 PM
  #153
smokeshow's Avatar
Mod with training wheels
They aren't stock head gaskets. Using MLS gaskets after the DOD delete. All seems okay.
Old Mar 20, 2010 | 06:59 PM
  #154
DOA's Avatar
DOA
I guess I was just generally asking, not specific to your install. But thanks.
Old Mar 20, 2010 | 08:34 PM
  #155
smokeshow's Avatar
Good question...stockers would probably be fine though.
Old Mar 21, 2010 | 12:39 AM
  #156
Spoolin's Avatar
GFYS and STFU
Some engine builders swear by the triple layer stock OEM head gasket. I ran stock ones on a built engine @ 18psi with no problems and Casey on here is running 22psi on stock gaskets.
Old Mar 22, 2010 | 11:25 PM
  #157
DOA's Avatar
DOA
Ok Gentleman,
I'm piecing together the rest of my Head/Cam/DODD/Ebay Charger install. Man there is alot of little expensive crap that adds up. This is the reason for my question.
The Ebay Kit says that you need the following parts:
TMAP Sensor (GM P/N: 90423637)
TMAP Wiring Jumper (GM P/N: 88988320)
Intake Gasket Kit (GM P/N: 89060413)
I picked up the intake gasket on Ebay for cheap, but I'm confused about the Sensor and the related Jumper. Are they needed? IF so, Why or why not? Is there away around this?
Thanks!
Old Mar 22, 2010 | 11:43 PM
  #158
smokeshow's Avatar
You can get around using the new tmap sensor by just tuning for the old one. You'll need to tap a hole in the intake and install an IAT sensor, and you'll also need to fab up your own little mounting bracket for the old map sensor. Overall you should save around $100.
Old Mar 23, 2010 | 12:28 AM
  #159
DOA's Avatar
DOA
Thanks,
Maybe its not worth saving a hundred dollars.....
Old Mar 23, 2010 | 12:31 AM
  #160
DOA's Avatar
DOA
Hey, do you have a photo of how you laid out your Tranny cooler and Intercooler?
