e-85 experiment
Old Jun 11, 2012 | 02:26 PM
kbracing96's Avatar
If your gonna run a mix, 25% is easiest for me anyway. The tank holds 26 gallons on most trucks, so the first time you put the mix in, put in 6.5 gallons of E85 and fill it with 93. That will give you apox 25%. From then on, just run the truck down to there is anout an 3/16-1/8 of a tank left, 4-5 gallons in it and then put in 5 gallons of E85 and 15 gallons of 93. That will keep you around your 25% mix.
If you have a WB gauge installed, you can keep an eye on it and if you seem a little richer then what you tuned for, add a little E85 it lean it out or if your a little on the lean side, add a little gas to fatten it up. That's what I do so I don't have to jack with the tune very much.
Old Jun 11, 2012 | 02:53 PM
smokeshow's Avatar
Mod with training wheels
I run 50/50, its very simple as well! lol Just equal amounts of every time. Put 8 gallons of each in last night
Old Jun 11, 2012 | 03:05 PM
idahoblkss's Avatar
upgrade that fuel system and run 100% e85 youll never look back. stuff is so magical it should be called unicorn blood.
Old Jun 11, 2012 | 03:19 PM
Atomic's Avatar
I have a gauge for that
I made a spreadsheet do to all the work, so you can just fill up with whatever and go...
https://www.performancetrucks.net/fo...ksheet-500126/
Ws6ickness
Feb 5, 2016 02:42 PM
LSXstef
Dec 22, 2015 08:31 PM
Gadgetized
Oct 22, 2015 09:06 AM
OHsixLS3
Sep 25, 2015 04:38 PM
BigKID
Sep 22, 2015 09:59 PM
