Dual Wastegates and STS EBCS
Old Feb 6, 2009 | 12:00 AM
  #31
Ender06's Avatar
is ebay the cheapest?
Old Feb 6, 2009 | 05:51 PM
  #32
FrostKing's Avatar
I bought my second spring from a local tuner shop (pricy) which was good for 3.5 psi. On a side note, my stock 5.7 engine/heads was nearly maxing out the single WG. I am installing a 2nd one this spring. I believe having more wastegate capacity will allow the boost to climb much faster and stay put rather than having the wastegate go wide open early and the boost slowly rise to the set point. With nothing else changing, 2 valves should have quicker boost buildup than 1 valve that opens 100%.
Old Feb 6, 2009 | 06:33 PM
  #33
parish8's Avatar
single digit dreamer
i dont see any reason why 2 valves would build quicker boost than one. the point is to keep the boost down and that is what more wg will help do. 2 valves will start to creep open just like one valve.
Old Feb 6, 2009 | 06:41 PM
  #34
FrostKing's Avatar
It was the case for me earlier where I needed to set the wastegate to 5 psi to maintain 8 at full throttle. A larger wastegate could have been set to 8 so the boost could have snapped to and stayed at 8 psi instead of slowly levelling off at 8 psi. If his single wastegate turns out to be undersized, 2 wastegates will provide quicker boost.
Old Feb 6, 2009 | 06:43 PM
  #35
FrostKing's Avatar
Now with bigger motor and heads, low boost spring (3.5psi) will max out my 2 bar.
Old Feb 6, 2009 | 06:49 PM
  #36
explorer5.0's Avatar
TOTM: November '07
For what its worth, the STS kit for a Ram SRT-10 includes two 38mm valves.
Old Feb 9, 2009 | 10:38 PM
  #37
Ender06's Avatar
Anyone here have a wastegate they would lije to sell???? Or a spring???
nabozny21
Oct 17, 2015 07:47 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
sTNT971
Sep 26, 2015 04:22 PM
