Dropped 2x Cylinders....
Old Sep 11, 2007 | 05:08 PM
Default Dropped 2x Cylinders....
dropped 2x cylinders in the 4.3....... cylinder 1 compression- 100 and cylinder # 3- 70psi.... truck still runs and i drive it to school lol....
so it looks like its time to start looking for what i have been dreaming about day and night
aluminum block 408 + GT76 + 1.06 + 4l80e + ford 8.8" in my blazer.
does anyone have any recommendations on who i should get a built short block from ?
what are the best heads?
good daily driveable boost cam with gobs of topend if thats possible?
looking for 140+mph trap speed...
looking for those kinda traps because i got a friend with a pretty powerful supra and i want to play with him on highway.
Old Sep 11, 2007 | 10:38 PM
WJ MARK's Avatar
Thats too bad. how long have you been running 13 psi??
Old Sep 11, 2007 | 10:45 PM
Quik's Avatar
5 year bitches!
on a 408 that 76 is going to be on the small side. how about a 88
what you going to do with your current sts kit?
Old Sep 11, 2007 | 10:53 PM
99Silverado5.3's Avatar
76mm is not going to get you to 140mph traps all boost unless you are around 3k pounds. Boost + spray I can see it happening with the right setup.
afr225 are awesome forced induction heads.
What are you looking for? Low # 1/4 time or highway monster?
Would be best to go with a SD tune rather than maf.
Old Sep 11, 2007 | 10:55 PM
Get a thumper 88mm turbo it will get you 140+mph all boost.
Old Sep 12, 2007 | 10:10 AM
highway monster. after looking im thinking about an GT47-88 1.08 DBB if it will fit under the hood or else twin 66mm's.
i want the truck to be fun on the street. i think a 408 will be fun enough in a 2door blazer. race weight should be and i quote SHOULD BE 3500lbs. im getting fiberglass fenders and going to put a fiberglass hood on it as well tubular front a-arms. its going to be done right. its gonna be a while but it will be worth it to pump out 140mph+ traps in a daily driven blazer on pump gas hopefully.
as for tuning. im probably going to run stock computer with HPtuners 3bar sd for a while until i can get BigStuff3 then turn the wick up...... im just going to prolly only run 4 or 5 psi for a while then turn it up to 8, then 12, then 16, etc. i am bye no means have the experience for a 1200whp vehicle let alone a 600whp vehicle. so i dont kill myself. give me some time to get a standalone.
i have run 13psi for the past 8monthes. ran 10psi for 6 monthes before that. the 4.3L held up really well.
ran 13.0 @ 99mph on a hot hot hot day @ 12psi with no tune.
my custom kit is for sale if anyone wants it for a blazer or s10 4.3L 4l60e. got an MPT70 w/ .70 a/r for sale as well and a garrett 60-1 P-trim .63 for sale.
Old Sep 12, 2007 | 11:01 AM
Quik's Avatar
5 year bitches!
for a TT 408 im going twin 67s
as for your kit what is all included? im curious cause my blazer is a dog. not looking for a drag truck just something with some more.....girls 4.0 cheerokee walks me constantly
Old Sep 12, 2007 | 01:07 PM
everything but the y-pipe. boost pipes, turbonetics 38mm w.g., intercooler, tb, couplers, t-bolt clamps, oil pump, oil cap return fitting oil lines, nozzle for meth already installed in the boost piping and will just leave it in. the 60trim needs a rebuild the T70 was only on for about a week
Old Sep 12, 2007 | 02:40 PM
Quik's Avatar
5 year bitches!
what you looking to get for it
Old Sep 12, 2007 | 05:00 PM
duwem's Avatar
Ha, school and 408/turbo in the same paragraph, you must work more/at a better job then I do at school to have the cash for this?????
