Dome or dish piston question
Old Nov 2, 2020 | 02:29 PM
64rcs's Avatar
Default Dome or dish piston question
I have a 2000 chevy RCSB with 5.3/4L80 and Huron Speed turbo kit. I reused the factory pistons and new rings gapped at 0.026. Roughly 15# of boost and #7 popped part of the piston apart. Block survived. This is just a toy so I don’t need or want anything stupid expensive. Looking at Summit Racing Pro LS forged pistons. My main question is do I go with the dish style or dome? Pump gas and driven on the street daily during nicer weather. And what rings? Apparently need to gap a bit wider this go around too LOL. Appreciate the help.
Old Nov 2, 2020 | 02:32 PM
wretched73's Avatar
You need to figure out what pistons will put you at the CR you are looking for.
Old Nov 2, 2020 | 02:46 PM
64rcs's Avatar
I don’t want to venture to far away from factory CR, hence pump gas and a DD at times. I have factory 862 heads and used BTR LS9 HG’s. I suspect the dish pistons is what I will go with but I wanted other opinions before I pull the trigger. I’m pretty green to the boosted world. Thanks
Old Nov 2, 2020 | 03:53 PM
wretched73's Avatar
Compression Ratio Calculator - Wallace Racing
Assuming 93 octane, shoot for ~10.5:1 CR
The calculator will help you put all the pieces together
Old Nov 2, 2020 | 04:54 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You might want want to consider a new tuner while your at it...
Old Nov 3, 2020 | 10:57 AM
BigKID's Avatar
I recommend the 7cc dish in the pistons mentioned to keep compression ~9.5:1 if keeping boost at 15# or more. The 2cc dome is going to put compression ~10.6:1 which isn't out of the tunable realm of 15# and 93oct pump gas but will need a really good tuner and solid fuel system to keep it alive. 10.6:1 will feel more responsive out of boost. 9.5:1 will be a little more forgiving with a 2618 piston if using a novice tuner and/or questionable fuel system.
Old Nov 5, 2020 | 10:45 PM
JustSurg's Avatar
What fuel pump are you running in that?
metalchip
Mar 20, 2020 01:09 PM
CodyBoy
May 5, 2011 08:39 PM
anheuserbusch08
Feb 28, 2011 09:04 AM
moes04silverado
Mar 6, 2008 03:35 PM
