DO i need or have 2 have a BOV?
i have been told that it is really unwise to not have a bov and then i have heard that it is fine on an automatic. i really just want to get it up and running and not having to deal with the extra $210 will help some so can someone please lemme know if its okay 2 not run a bov for a while. its not that i dont want to spend the money its just its $210 i could spend on tuning.
You should be fine without a BOV below 12 psi and running an automatic transmission. Without a BOV you can make it a little easier on your system by not lifting abruptly off the throttle from high boost. Lifting abruptly is also very hard on the rotating assembly so it is best practice to ease off the throttle after a WOT run. I know it is not always possible but think about it and try to avoid abrupt throttle transitions closing the TB plate from WOT.
No you should be OK. It is my understanding that the BOV starts to become more essential over 12 psi. or if you have a manual trans as already stated. If you never close the throttle plate abruptly you will never have a problem. If you do a lot of 1/4 mile runs at the track and constantly need to close the throttle quickly at the end of the run then you might consider adding one at that time. The BOV is really more for a manual trans that has the throttle plate slammed shut before every shift. That is not a problem with an automatic transmission.
Originally Posted by Wilde Racing
A BOV is recomended with higher boost. or a standered trans. But if you run your waste gate line from the intake manifold like most do, the bov won't work anyway. Well atleast mine don't.
Do I need to sell this thing???
what kind of woman takes their foot off the throttle between shifts? (no offense to any of you ladies out there)
but yeah, I need a BOV for mine...but thats because well, I like blowing off on people from a truck
How do I change this text
Originally Posted by TG02Z71
Yours doesn't work?!?!?!!?! I bought one a while back and have never installed it yet because I have not went over 7-8psi yet.
It worked fine until I move the bov and had to extend the hose. Well at least I can't hear it any more. Here is what it looked like before
BOV Video
Originally Posted by quicksilverado
How is the bov incorporated into the wastegate and vacuum lines?
I edited my first post.
