Do I need a 3 bar LS9 map sensor?? Whipple
Old Apr 23, 2018 | 10:19 AM
snogoer's Avatar
Default Do I need a 3 bar LS9 map sensor?? Whipple
I am building a LS3 whipple build for my 2009 Sierra Denali. Do I need to buy and switch to the LS9 3 bar map sensor? If so why, and is there anything else I need to switch to the LS9 sensor on my LS3?
Old Apr 23, 2018 | 10:22 AM
Vortec350ss's Avatar
On the newer PCM its not quite as important to go 2 or 3 bar. I would venture a guess 2 bar would be fine unless you think you'll run more than 15psi.
Old Apr 23, 2018 | 10:32 AM
Atomic's Avatar
I have a gauge for that
May as well, wont hurt for when you decide to put on a turbo.
Old Apr 23, 2018 | 10:51 AM
snogoer's Avatar
Okay thanks. I plan on running right around the 12-14psi range for the daily
Old Apr 23, 2018 | 10:53 AM
snogoer's Avatar
Haha, is it Strickly a plug and play deal? What’s has to be changed?
Old Apr 23, 2018 | 10:56 AM
FFDP's Avatar
You need to swap the wiring on the MAP sensor plug. From memory only the 2011+ or 2012+ trucks were plug and play with the MAP sensor. It's only 2 wires you have to swap.
Then the tune must be changed for the new linear and offsets for the MAP sensor. They are 312.50 and -11.25.
Old Apr 23, 2018 | 11:34 AM
snogoer's Avatar
The wires are color coded do you remember which wires?
timmay208
Oct 12, 2014 07:50 PM
cpolaris502
Apr 30, 2014 05:06 AM
m7 rocket
Jun 9, 2006 08:19 PM
dc96819
Apr 4, 2006 11:44 PM
TurboGibbs
Nov 10, 2005 09:06 PM
