DD turbo trucks
Old May 23, 2007 | 08:50 AM
vanillagorilla's Avatar
I drive mine everyday, obviously except for when it was down for tranny and clutch swaps. I've put a little over 15,000 turbocharged miles on it, and my only issue is oil control. I contribute this to a lovely mail order tune on the stock fuel system that burned some rings. This isn't a normal issue though if you keep you tune in check. I haven't towed a trailer, but I've had well over 1000lbs in the bed several times with no issues at all. I have towed another ECSB truck for a short distance, but nothing I'd consider towing.
As far as longevity, a turbo can last on long time, if you keep up on your oil changes.
Old May 23, 2007 | 10:20 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by kbracing96
every once in a while when I feel really spunky...
Spunky?
I DD my turbo truck too, when it has an engine and is not on fire. The turbo itself has been fine. The other problems are unrelated to the turbo, but I tow and all that other crap too with no problems.
Old May 23, 2007 | 10:55 AM
blockheadnic's Avatar
10 Second Club
Well that the stuff i like to hear, i am going start haulin my drag car around. I wasnt sure if people had any trouble doing so.
I was lookin to get a gt- 67 For my pretty much stock truck, with cam, torque convertor. WOuld the 67 be ok for stock, or should i go smaller or bigger. i dont care about mpg, truck already gets 13 the way i drive
Old May 23, 2007 | 11:04 AM
ChevyThunder17's Avatar
I would recommend looking into the Trick Turbo setup. Their setup uses a 62-1, which is a bit smaller than the GT-67 (IIRC). It appears to be a well built setup, I'm looking at getting at least the hotside parts from them once my financial situation stabilizes.
Old May 23, 2007 | 11:11 AM
10 Second Club
How much are just the hot side parts? Theres a place close to were i live that turbo anything, and have a good reputation They turboed a cadilac STS it was bad ***. I think i may have them do the hotside and i do everthing else
Old May 23, 2007 | 11:31 AM
Shoot a PM to TrickPerformanceProducts. They are a sponsor on this site.
Old May 23, 2007 | 11:50 AM
kbracing96's Avatar
Originally Posted by thunder550
Spunky?
Don't make me dig the pic out of what else I tow with my truck
Old May 23, 2007 | 11:57 AM
Switched's Avatar
Ive put about 1000 miles on my Sts DD truck and other than a few minor problems (Mostly my fault ) It runs great. But it can get spendy fast theres always somthing to buy/upgrade. i think ive spent close to 8 or 9 thousand dollars so far.Other than that PT.net Was the best single resource that i had while i was puttin my turbo on.
Old May 23, 2007 | 12:53 PM
HA! That's what I was thinking about when you said you've towed with it.
Old May 23, 2007 | 01:46 PM
thunder550's Avatar
Jerks I'm going to go cry now.
