Daily drive your blown forged trucks?
Old May 28, 2009 | 11:30 AM
  #31
GMCtrk's Avatar
Originally Posted by PSM
Have you watched you tps when you get on it. I found what I thought was 1/4 throttle was much more. According to my tps I'm at 30-33% just to cruise @73mph. I find I don't get a good shove in the back until I get closer to 50%+ tps. Maybe the blower isn't the way to go to get power down low..... I really need to drive a trubo ls truck to see what its like at part throttle.
My truck really starts accelerating on the highway with the verter locked at around 30-35% TPS. I never see > 40% unless I got WOT
Old May 28, 2009 | 03:55 PM
  #32
PSM's Avatar
PSM
Originally Posted by BigCountryx
A good shove in the back as you approach 50% TPS sound perfect to me, why would you want a daily driver to get into boost earlier than that. That's what I love about FI, esp a Maggie, is that you would never no it's there until you lean into it a little, then wow. I love the driver friendly attitude it has putting around town and in traffic, very predictable and easy to drive when you need it to be. of course that's JMO.
I understand what you are saying and that does make the maggie a great bolt on that you use when you want it.
What I find anoying/funny is when i'm kinda getting on it at almost boost, then i give it enough to get into boost.. the tc just slips more and the truck doesn't actually accel any faster. I wish I could experience the radix tq w/ a manual trans.
Old May 28, 2009 | 04:26 PM
  #33
GMCtrk's Avatar
So why dont you just set your converter to stay locked? Like I said on mine, the only way my converter comes unlocked is if I go WOT.
Old May 28, 2009 | 08:41 PM
  #34
quicksilverado's Avatar
Turbos are completely different compared to positive displacement blower. The blower is closer to an on/ off switch when compared to a turbo vehicle. With a turbo you just give it a little gas and it will build just enough boost to get you going. Having had both the turbo seems much better on the highway in my opinion.
Old May 28, 2009 | 09:29 PM
  #35
PSM's Avatar
PSM
Thats why I'm buying efilive. I originally had this truck tuned by slowhawk, but I realized I'm jsut way to picky to keep going back to some one. Do you lock through shifts at part throttle?
After experiencing the blower I do wish I had been able to drive a turbo ls truck. I think I would have gone the other way.
Old May 28, 2009 | 11:20 PM
  #36
GMCtrk's Avatar
Nope, only time my converter locks is in 4th cruising. I dont think it's advisable to lock the converter thru shifts. Im strongly considering a Circle D 4l80e triple disk converter which will allow WOT lock up however.
Old May 28, 2009 | 11:26 PM
  #37
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you lock through the shifts youll be buying a new input shaft in short order
Old May 28, 2009 | 11:44 PM
  #38
silver-mod-o's Avatar
Hunt&Fisherator
If you had an aftermarket (higher stall speed) converter you could lower your unlock TPS and when you wanted to pass, it would take less throttle to get you back in the power... It really wouldn't make much difference with the stock converter... Mine locks above 50mph and less than 30% TPS and unlocks with anything over 50%.... It just takes LOTS of tinkering and fine tuning to get it where it works for you.
Old May 29, 2009 | 01:51 AM
  #39
So Far Ive gone 80K on stock internals blown to 10 lbs. I usually hit 6-7 lbs daily. These motors are strong stock. Its all in the tune
Old May 29, 2009 | 05:08 AM
  #40
PSM's Avatar
PSM
All in the tune.... as in keep the afr kinda fat at 11:3 or so and keep spark timing low enough to prevent knock?
