cutting out in boost
Old Mar 23, 2017 | 07:09 PM
GMCtrk's Avatar
.04 that's your problem
What your describing is classic blow out
Old Mar 23, 2017 | 07:23 PM
03sierraslt's Avatar
Yep.
.04 is too much. Spark blowout and the resulting misfire will cause all kinds of erratic air/fuel readings.
Old Mar 23, 2017 | 07:29 PM
LOWnEASY's Avatar
Well, didn't cut out this time, but it whent to reduced power at 5600 rpm
Old Mar 23, 2017 | 07:47 PM
Atomic's Avatar
I have a gauge for that
Theres a table you need to increase to fix that
Old Mar 23, 2017 | 07:52 PM
LOWnEASY's Avatar
Elaborate please
Old Mar 23, 2017 | 08:14 PM
LOWnEASY's Avatar
Could it be the p0068 tables?
Old Mar 23, 2017 | 08:28 PM
Atomic's Avatar
If the DTC you were getting when it went into reduced power was p0068 then I would say thats a good place to start. Multiply by 3.
Old Mar 23, 2017 | 08:32 PM
LOWnEASY's Avatar
I believe it was somthing about map, maf correlation. Cleared them, done another hit went in R.E.P with no codes the second time.
What's happens if there maxed out? Can't I just max out the enable rpm?
Old Mar 23, 2017 | 08:41 PM
LOWnEASY's Avatar
On a side note I did hit 15 lbs at 5500 rpm. still have 1500 rpm to go be for the blower is maxed feels great until reduced power hits
Old Mar 23, 2017 | 09:28 PM
LOWnEASY's Avatar
well maxed the tables out and no more REP. but now my poor walbro 450 is maxed out with the stock 58 psi. I don't think 140% IDC is going to work
most likely going to cut the B.S and go with a sump, and magnafuel 4303 and call it a day
thanks for the help guys.
