Custom AC lines??
Old Dec 29, 2018 | 09:14 PM
Rhvr6's Avatar
Default Custom AC lines??
Has anyone had custom AC lines made? I’ve been searching and no luck so far. Thanks in advance.
I would need a 90 right off the dryer
Old Dec 30, 2018 | 09:24 AM
milesp07's Avatar
I did. I bought some adapters from eBay and fittings, then had a local shop in Austin crimp it for me. It worked like a champ and I didn’t have to worry about bending my stock line.
Old Dec 30, 2018 | 09:50 AM
Drizzy's Avatar
Check out Huron Speed. They offer a custom AC line upgrade with the purchase of their kits. May be able to buy it separate.
Old Dec 31, 2018 | 07:35 AM
Rhvr6's Avatar
Default Thanks!
im going to give the Huron line a shot, hopefully that will do it and won’t have to go the custom fabbed route.
Old Jan 4, 2019 | 03:16 PM
Rhvr6's Avatar
no luck with the Huron product, its a single line off the newer body style. This is a 2000. Can you share any more info on what it took?
Old Jan 5, 2019 | 07:07 AM
kbracing96's Avatar
Just get the compressor and lines off a 2001+ truck. They don't have those canister things on them like your truck does and should be able to make them fit around the turbo manifold.
Old Jan 5, 2019 | 10:31 AM
milesp07's Avatar
here’s what my line looks like. I’m taking my turbo kit off the truck so you can get a real good idea of where it run. I bought adapters for both the dryer and compressor. I used a 45 at the dryer, and a 90 at the compressor. I got much more clearance than just bending the line. I’m sure you could bend it and be fine, I just wanted the extra assurance I wasn’t going to have a problem.
Old Jan 5, 2019 | 12:44 PM
Rhvr6's Avatar
Thanks! Same for the dryer or convert the OEM bolt on to AN? Hose length and clearance at the dryer are gonna be tough.
Old Jan 5, 2019 | 12:45 PM
Rhvr6's Avatar
Very helpful, thanks!
Old Jan 5, 2019 | 05:53 PM
milesp07's Avatar
Yes, both bolted on to convert from the factory connection to AN.
