Custom AC lines??
https://cimg9.ibsrv.net/gimg/www.per...4970b8276.jpeg Has anyone had custom AC lines made? I’ve been searching and no luck so far. Thanks in advance. https://cimg0.ibsrv.net/gimg/www.per...27dc9cb1b.jpeg I would need a 90 right off the dryer |
I did. I bought some adapters from eBay and fittings, then had a local shop in Austin crimp it for me. It worked like a champ and I didn’t have to worry about bending my stock line.
Check out Huron Speed. They offer a custom AC line upgrade with the purchase of their kits. May be able to buy it separate. |
Thanks!
Originally Posted by milesp07
(Post 5454592)
no luck with the Huron product, its a single line off the newer body style. This is a 2000. Can you share any more info on what it took?
Just get the compressor and lines off a 2001+ truck. They don't have those canister things on them like your truck does and should be able to make them fit around the turbo manifold.
https://cimg1.ibsrv.net/gimg/www.per...1323001b3.jpeg https://cimg2.ibsrv.net/gimg/www.per...8a8a5092d.jpeg https://cimg3.ibsrv.net/gimg/www.per...fe45aa289.jpeg here’s what my line looks like. I’m taking my turbo kit off the truck so you can get a real good idea of where it run. I bought adapters for both the dryer and compressor. I used a 45 at the dryer, and a 90 at the compressor. I got much more clearance than just bending the line. I’m sure you could bend it and be fine, I just wanted the extra assurance I wasn’t going to have a problem. |
Thanks! Same for the dryer or convert the OEM bolt on to AN? Hose length and clearance at the dryer are gonna be tough. |
Very helpful, thanks!
Yes, both bolted on to convert from the factory connection to AN. |
