Critique my Trick 76mm turbo numbers and advise on how to make additional 100whp
Old May 31, 2016 | 05:23 PM
  #41
lxcoupe's Avatar
Originally Posted by GMCtrk
aren't you running E85?
If so, You don't need to pull any timing
Yes I am. Is it as simple as zero'ing out the IAT vs spark correction table when running E85? I'm thinking my IAT's would have been even higher if it hadn't pulled timing? I still think that 190* IATs are something that need to be corrected, regardless. Here's what my table looks like:
Old May 31, 2016 | 09:17 PM
  #42
Atomic's Avatar
I have a gauge for that
I would cut that table in half but not zero it out. E85 can still detonate. Its harder to do so, but it can happen. I would agree 190 IATs are way too hot. At that point I bet you would gain power with a half decent intercooler.
Old May 31, 2016 | 09:28 PM
  #43
lxcoupe's Avatar
Great info thank you. From my research, ideally my IATs shouldn't go too much past 30 or 40 above ambient if the intercooler is sufficiently efficient so technically that spark correction table might not be as relevant once I upgrade the intercooler. I'll have more data this week once the new intercooler goes on and I can get back to the dyno.
Old Jun 1, 2016 | 07:24 AM
  #44
GMCtrk's Avatar
190 is nothing to worry about
Old Jun 1, 2016 | 10:44 AM
  #45
kbracing96's Avatar
My supercharger used to get up to 240 with 17psi at the end of a 1/4 mile run!
1994Vmax
23
Aug 4, 2016 03:24 PM
greenturtle05
Apr 28, 2016 10:44 PM
4xRCSS
Mar 4, 2016 10:10 AM
4xRCSS
Mar 4, 2016 09:40 AM
