Coolant Tank Problem on Turbo Silverado
Old Mar 1, 2018 | 03:28 PM
  #21
Mercier's Avatar
Forgot to mention one detail of filling through the top hose. When doing so, you can leave the output from the steam setup unhooked and fill until you get coolant from there. Then connect that, keep filling through top hose. Theoretically not necessary, but that usually gives me peace of mind that I got most or all the air out of the tops of the heads.
Old Mar 1, 2018 | 07:53 PM
  #22
gdbutcher's Avatar
Originally Posted by Atomic
Wow you guys really struggle with this. On all my coolant tanks ive had or the custom ones I make you just fill to 3" below the top and go. Never had a burping issue or anything else for that matter. If I overfill it will puke out the excess the first time it gets hot, but never gets low enough to not keep the pump primed, unless you blow a headgasket of course.
Where can I find your tanks Atomic!? Pictures and where can I order them. I'm shopping for a new bigger tank and ditching this little Aveo tank.
Old Mar 1, 2018 | 09:22 PM
  #23
Atomic's Avatar
I have a gauge for that
I have them on my website (welded or diy kits) and also have this coolant tank breather can combo I need to get rid of I have sitting around.
Attached Thumbnails Coolant Tank Problem on Turbo Silverado-20180211_155348.jpg
Old May 11, 2018 | 07:53 AM
  #24
gdbutcher's Avatar
UPDATE: I rigged up my old stock coolant tank and haven't had a single problem yet. Problem solved.
Old May 11, 2018 | 10:10 PM
  #25
TrickTurbo's Avatar
Truck Sponsor
Is that little tank vent hose pre or post cap?
Is it an overflow port.
Old May 11, 2018 | 10:36 PM
  #26
Atomic's Avatar
If you are asking about mine that is an overflow port, post cap.
Old May 12, 2018 | 03:38 AM
  #27
TrickTurbo's Avatar
Truck Sponsor
No,
I was asking about that little plastic one.
Ferocity02
Apr 21, 2023 02:52 AM
foose04
Jan 16, 2023 12:54 AM
Hemi Killer
22
Sep 27, 2009 08:58 PM
parish8
20
Mar 25, 2004 11:31 PM
