controlling boost off the line ...
what are you guys doing to control the boost off the line while at the light. if i brake stall my truck and let off when it hits 8 psi it launches hard but breaks loose a little bit but if i hold it till 12 psi the truck turns into a hover craft "awd burn outs". what are you guys using or doing to control the boost at the light so you dont over boost and blow the tires off? im using a eboost2 as a controller and would really like to get this dialed in before i hit the track in 2 weeks.
I used to just hit the button on the eboost to go to a preprogrammed higher setting as it shifted to 2nd. 14psi in 1st then 25 in 2nd. Slows you down quite a bit but works if you are traction limited.
so you just watch your gauge and feather the gas pedal ? what tires are you running , im just afraid if it hooks to good its going to break stuff i was thinking about getting some et streets.
