cold air box on turbo
Old Aug 26, 2015 | 08:35 AM
tim wellington's Avatar
Default cold air box on turbo
any one running a cold air box on turbo set up .the one that completely cover air filter .it feeds air to turbo through bottom feeder well.
Old Aug 26, 2015 | 09:08 AM
Jake75's Avatar
Not a cold air box but I made a sheet metal cover for my air filter and covered it with DEI cool tape. Seems to be helping IATs a little bit...if that's your goal
Old Aug 26, 2015 | 10:55 AM
walledition's Avatar
Interested in this aswell, pictures of ideas would be great
Old Aug 26, 2015 | 10:57 AM
RS/SS 4.8's Avatar
10 Second Truck Club
Im using the stock box on mine. I have a duct feeding air from the lower right corner of the bumper to the bottom of the box.
Old Aug 26, 2015 | 12:18 PM
blownescalade62's Avatar
Here is mine.
File Type: jpeg
Old Aug 26, 2015 | 02:27 PM
did u make this box? looks clean
Originally Posted by blownescalade62
Here is mine.
Old Aug 26, 2015 | 05:07 PM
black00chev's Avatar
Slowest turbo build ever!
This is what I ultimately want to do with my SLP box when I go turbo. Even if I had to cut a new hole where the current filter mounts.
Old Aug 26, 2015 | 06:16 PM
ZO6Ted's Avatar
I think I'm more anxious than you are to see you do it! When for God's sake are you going to? C'mon man!
Old Aug 27, 2015 | 07:11 AM
Default i.a.t
that what i was thinking i was doing some data logging .i noticed when fans are on high .temp drops on engine . but i.a.t goes up .think turbo sucking the the hot air off radiator
Old Aug 27, 2015 | 02:29 PM
Jake75's Avatar
I was running an open turbo (no filter) and my iat would be 150+ WOT with water/meth and 93 octane.
I put the shield on with a filter and my iat are around 120 WOT in the Texas heat. Ill post a pic later its not the prettiest but gets the job done and only cost 26 bucks. 6 dollars for the stainless sheet at home depot and 20 for the cool tape.
I also wrapped my intake charge pipe with the DEI cool wrap
mzoomora
Jan 3, 2016 07:06 AM
5.3Caprice
Aug 1, 2015 07:40 PM
Matt331
Jul 26, 2015 09:40 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
