Cobalt map sensor
Old Sep 8, 2009 | 03:19 PM
ONLYA4.8L's Avatar
Default Cobalt map sensor
I was thinkin of usin a cobalt map sensor since I'm runnin boost.. I hear it measures Boost and wondering if its true
Old Sep 8, 2009 | 05:42 PM
MNC5's Avatar
Get the right one the cobalt has a baro and map sensor. Call 1st and make sure they have the correct one.
Old Sep 8, 2009 | 06:37 PM
Rick_Vor's Avatar
2 Bar Map sensor updated part # 12615136
Old Sep 8, 2009 | 08:32 PM
TURBHOE's Avatar
i believe the baro is what you want cause it is two bar. the map on those is 2.5 bar. check out hptuners.com/forum.
Old Sep 8, 2009 | 09:18 PM
silver-mod-o's Avatar
Hunt&Fisherator
My Cobalt MAP sensor has never read 2 bar... I've done everything I can think of, and it still won't go over 105kpa...
Old Sep 9, 2009 | 12:28 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
if i wanted to run 15-20psi what map sensor will i need??
Old Sep 9, 2009 | 02:20 AM
ONLYA4.8L's Avatar
i wanna know what i need as well
Old Sep 9, 2009 | 06:16 AM
Mort's Avatar
3 Bar. You will not find a direct replacement AFAIK. You will need an aftermarket sensor reading 0 - 5 volts and run a vac line to it from the intake manifold and then wire it up to the wires that go to your stock sensor.
2 bar - up to 14.5 psi boost.
3 bar - up to 29 psi boost
Old Sep 9, 2009 | 06:20 AM
Mort's Avatar
GM MAP Sensor # 12615136 is a direct replacement 2 bar map sensor as stated by Rick_Vor above.
Old Sep 9, 2009 | 06:24 AM
Mort's Avatar
I don't think you have the right one. Ask KB or get the one listed above and I believe it is the one from the Cobalt that reads 2 bar. Mine reads fine to 13 psi boost but I have not run it out to a full 2 bar yet.
