Charger problems need "HELP"
Old Dec 15, 2005 | 10:45 PM
charged327's Avatar
Default Charger problems need "HELP"
Hey guys i need help i finally put the charger on the truck but its got a misfire in cyclinder#1,5,7. my questions is do i need to put colder plugs than the ones that the truck comes with from factory? and if i do what degree are the factory ones? and how much colder do i need to go? please let me know asap thanks guys
Old Dec 16, 2005 | 04:08 PM
TwoFast's Avatar
do you have a Radix supercharger installed?
I'm running NGK TR6 plugs in my truck with my blower.
Old Dec 16, 2005 | 07:47 PM
03sierraslt's Avatar
What kind of supercharger do you have? What all did you change when you did the install? What type of tuning are you using?
Old Dec 17, 2005 | 06:57 AM
vanillagorilla's Avatar
SUPERcharger, TURBOcharger, SAN DIEGOcharger????
Old Dec 17, 2005 | 09:15 AM
Clever Vanilla.....
Old Dec 17, 2005 | 12:27 PM
ogkevin13's Avatar
Banned
i have the ngk tr-6 on my turbo set up. but cly#7 and #2 where misfiring and i blew the motor piston number 7 only put out about 20 pounds of compression so i didnt feel comfortable patching thet motor so i went with a swap and am building the motor that blew. good luck man
Old Dec 17, 2005 | 04:46 PM
charged327's Avatar
well guess what cyclinder#7 has no compression the problem is that the guys from nelson tune told me to go ahead and use the tuner but the tuner was programmed to 9 lbs and so the tuner was not pushing enough fuel and the truck was boosting 11lbs but they said since i put bigger injectors it was fine and to go ahead and use it, so you know what happen from there. honestly i messed up i shouldn't have listen to them but i'm a beginner and i guess i'll learn what to do from now on
Old Dec 17, 2005 | 06:43 PM
ogkevin13's Avatar
Banned
same here i learned from my mistakes also. sts told me to get installed in a shop they knew ( which i went there) sts also sold me a tune and said i would be fine they calibrated everything to sts specs. then 2,000 miles later my motor blew. my rig only has 30,000 miles. i call sts and tell them whats up and all they said was sorry we cant help you . they said my tune was off (no ****) and everything was set to there specs. i dont know **** them. but then i pulled the money back from the credit card haha . go with a good swap man. and just build the one you have right now and set it as a back up
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
