changing pulleys
Old Oct 29, 2006 | 05:01 PM
whoopassracer's Avatar
well i put the 3.1pulley on and im seeing 7.5-8lbs of boost on my boost gauge and on my 2.75 i was seeing 10.5-11lbs of boost. see if my timing go's up and do a better time.
Old Oct 29, 2006 | 09:57 PM
Last Call's Avatar
TOTM: January 2007
You are going to need tune for the 3.1 pulley. Probably add more timing and adjust the fueling. 3-4 psi needs a different amount of fuel and timing. Running it with 3.1 pulley with the 2.75 tune and 8 degrees of timing, the truck is probably going to feel like crap. Porbably be super rich.
Old Oct 30, 2006 | 04:24 PM
well its ok cuz im going to nelson next thursday to retune with the 2.75 and the Speed Density Tune with the meth kit also on dyno
Old Oct 30, 2006 | 07:05 PM
Are you using any scanning software?How do you know how much timing you are running?The meth system will allow you to safely run more timing,but you'll need to change your timing tables to allow more boost.If you use an aggessive tune,you'll need to monitor for KR to keep from damaging your motor.
Old Oct 30, 2006 | 07:29 PM
i have the nelson tune. thats what it read on the software
lsxperformance
Apr 20, 2016 12:17 AM
thunder550
Oct 8, 2015 04:53 PM
chevysten
Aug 13, 2015 07:36 PM
Ls3silverado
Jul 31, 2015 04:22 PM
bigsapper
Jul 28, 2015 12:56 AM
