Catch cans on trucks?
Old Apr 3, 2016 | 04:50 PM
TrickTurbo's Avatar
Truck Sponsor
Default Catch cans on trucks?
Which one do you use?
How is your system set up?
PCV or to
Atmosphere.
Old Apr 3, 2016 | 05:20 PM
FFDP's Avatar
I found a few threads with some answer that might help you.
https://www.performancetrucks.net/fo...ations-537897/
https://www.performancetrucks.net/fo...-boost-538436/
Old Apr 3, 2016 | 05:55 PM
BlackGMC's Avatar
Resident Retard
Here is the ine i use on my truck and CTS. I have it hooked up via pcv
PVC Oil Catch Can - Custom Product
Old Apr 3, 2016 | 06:18 PM
TrickTurbo's Avatar
Truck Sponsor
Mike Norris Seems to be a popular one I see.
CHODA used one on his build with good success.
Old Apr 3, 2016 | 09:43 PM
LongBlue's Avatar
PCV or to
Atmosphere.
Mighty Mouse PVC catch can. Has a check ball built in to dump any internal engine pressure. Nice product.
Old Apr 3, 2016 | 09:50 PM
AlwaysOnKill's Avatar
PCM of NC Catch Can Kit I've ran on multiple cars . This is all you need with the check valve .
Old Apr 3, 2016 | 10:16 PM
GRRR65GTO's Avatar
Both valve covers to can to atmosphere
Bough mine from a guy on ebay who makes a bunch of different configurations
Old Apr 3, 2016 | 10:33 PM
TrickTurbo's Avatar
Truck Sponsor
Anyone with breather type cans notice oil smell inside the cab while cruising.
Old Apr 4, 2016 | 12:02 AM
AkSSS's Avatar
I have a MM pcv can that I decided to just vent both valve covers to atmosphere. I have about 1200 miles on the new motor and setup. The first 100 miles getting the motor broke in I had a small break in smell. After that I have never smelled any oil. I did run a vacuum line to the can do the crank case would have some vacuum on it out of boost.
I ran 2 #8's from the valve covers to the can also.
Old Apr 4, 2016 | 07:36 AM
Choda's Avatar
Yup, I like it, amazed how much oil it actually picks up. I also use the Boomba racing check valves.
Check Valve, 10 mm, 3/8", aluminum
