Catch can and higher boost
Old Jul 1, 2015 | 10:04 AM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by AkSSS
Do you need to have that vacuum on the crankcase? If you are already venting both valve covers why the need for the vacuum?
This is no big power setup. I am expecting around 650awhp but I am hoping for 750awhp.
big power setups sometimes run a vacuum pump on the motor to help seal the rings and etc
for stock setups with boost venting both valve covers and the valley cover to a catch can is all ya need. Ive done every build ive done like this since 2008
thats alot of boosted combos, sucking oil back into motor is never a good thing and can lead to detonation in some cases
Old Jul 2, 2015 | 01:48 AM
AkSSS's Avatar
I still haven't made a decision on this yet. I was dead set on just running the two valve covers to a can. I don't have any ports on my gen 3 valley. I wonder if the 2 #8 ports would do it?
I think I want the simplest I can make it. I can always change it later. As long as the pressure always has some where to go.
Old Jul 2, 2015 | 07:10 AM
Formerly ScreamingL
LS6 valley cover has the port
Old Jul 2, 2015 | 11:52 PM
AkSSS's Avatar
Thanks George. I am going to just vent the valve covers to the catch can and see how that works for me. I can always change it if I don't like the results.
Old Jul 5, 2015 | 01:16 PM
I just put in a monster rx catch can but I am going to change to venting both valve covers to it ....
1 hose goes to throttle body...has a one way valve...
1 goes to supercharger boot input side, has a one way valve...
1 goes to valve cover with other cover with a breather..
Old Jul 6, 2015 | 10:32 AM
AkSSS's Avatar
If you run both your valve covers to the can, how are you going to run your third line?
Old Jul 7, 2015 | 05:54 PM
I will tee in the valve covers to the middle line...fittings on order will post pics
Justin87gn
Sep 10, 2015 12:06 PM
custm2500
Sep 8, 2015 05:53 PM
06murder
Sep 4, 2015 03:54 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
