Can some one please help me with a fuel system? Turbo 5.3
Old Feb 18, 2014 | 08:22 PM
99Ls1fever's Avatar
11 Second Club
Default Can some one please help me with a fuel system? Turbo 5.3
I have a 2000 Sierra 5.3
I just purchased a Turbo kit for my 5.3 Truck and have been asking Multiple questions about the trucks fuel systems and haven't had anyone write me back or tell me any real info.
Questions I have:
Is the truck drop in fuel body housing the same as a LS1 Camaro Trans AM? Meaning can I just buy a 340lph fuel pump for a 98-02 Camaro and it will be a direct fit in the truck in tank housing?
Does somebody make fuel pumps in-tank specifically for Trucks/SUV's drop in tank pumps 340lph+ ?
If not what is required to take a 340lph pump or 4xxlph and wire it in correctly or modify the stock housing to except it?
Is there a harness someone makes if the pumps are not direct plug and play wiring?
Thanks
Old Feb 18, 2014 | 08:26 PM
Atomic's Avatar
I have a gauge for that
It is not hard to wire in and fit one of the larger pumps. If you know how to use wire strippers you can do it, but I do recommend upgrading the wiring to the pump to 10 or 12ga.
Old Feb 18, 2014 | 08:27 PM
GMCtrk's Avatar
Walbro 400/450 lis essentially a drop in replacement. Requires minor bucket modifications. You need a hotwire kit and in tank wiring harness, which racetronix sells. Also make sure you have the newer style flat 4 pin electrical bulkhead. The old square 4 pin connector isn't rated to handle the current that the big walbro can pull.
This setup on an otherwise stock fuel system with injectors is good for about 600 rwhp on E85 and probably around 800 on gas.
Old Feb 18, 2014 | 08:29 PM
99Ls1fever's Avatar
11 Second Club
Thanks
Does racetronix sell the walbro 400's?
Old Feb 18, 2014 | 08:31 PM
GMCtrk's Avatar
No. I bought one of ebay recently for 137 shipped though. Can't beat it for the price. And quieter than the stock pump too lol
Old Feb 18, 2014 | 09:00 PM
99Ls1fever's Avatar
11 Second Club
could you link me to it?
Old Feb 19, 2014 | 07:11 PM
99Ls1fever's Avatar
11 Second Club
Called on3 performance and they sold me a 340lph pump that fits in the stock hat with a plug and play wiring harness for $70.00 bucks
Old Feb 19, 2014 | 10:15 PM
oakley6575's Avatar
Good luck with that pump . Heard nothing but shitty stories about them
Old Feb 20, 2014 | 12:50 AM
99Ls1fever's Avatar
11 Second Club
care to enlighten me....?
Old Feb 20, 2014 | 01:05 AM
oakley6575's Avatar
Just do a search on that pump. There are a lot of failures. Walbros are a great pump that are super reliable, quiet, ect. Why did you choose against them?
