cammed 5.3 safe to whipple?
Old Jun 17, 2013 | 09:55 PM
bs4.8's Avatar
holy sh#t , thing goes pretty good huh, sounds awesome..ill be buying it Wednesday,after that ill get a walbro 255 and 42lb injectors correct?
Old Jun 18, 2013 | 06:52 AM
trxmxzx's Avatar
13 Second Truck Club
Get the pump do a search for the summit part number it might come up, the injectors I think you'll be safe with 5 psi. I'm at 63% injector duty cycle with 60lb.
Old Jun 18, 2013 | 07:17 AM
06murder's Avatar
theres guys on here run 15-20 psi on stock bottomends
Old Jun 18, 2013 | 03:58 PM
bs4.8's Avatar
you guys are saying at 5psi 42lbs will be safe or stock injectors will be safe
Old Jun 18, 2013 | 08:12 PM
trxmxzx's Avatar
42lb youll be close to maxing out at 5 psi i believe- who's doing your tuning?
someone else could chime in that would be awesome
my stock injectors were basically maxed out with just the cam.
Old Jun 18, 2013 | 08:16 PM
black04's Avatar
42s would be fine up to 8-9 psi. I had the whipple on my 5.3L with a 216/224 115lsa cam and 3200 converter. Truck was a blast to drive. Just make sure you delete the whippletronics and just run a good tune. You need to relocate the IAT sensor to the pressure side as well to make it safe.
Edit: I ran a stock fuel pump and it was fine at 7psi
Sexyrado327
Aug 2, 2015 04:08 PM
MS3Z
Jul 30, 2015 06:17 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
