cam for my Whipple
Old Dec 29, 2012 | 10:50 AM
ou812sm's Avatar
Default cam for my Whipple
Here are the cam specs 219/229 .550/.550 lsa 114 I would be putting this cam in to my whipple charged 2009 Sierra Denali the whipple has a 3" pulley on it as for other mods to the truck are cai, headers, catback and that is it how do you guys think rhis cam will do
Old Dec 29, 2012 | 11:15 PM
Boober's Avatar
3" pulley? As in 3.000"? What boost are you running?! 15psi? That's some serious boost for a stock 6.2 and no meth.
Old Dec 29, 2012 | 11:33 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't pick that cam for a blown 6.2.
Old Dec 29, 2012 | 11:37 PM
ltr450ryder's Avatar
Seems really small to me
Old Dec 29, 2012 | 11:39 PM
I'd go bigger split, more lift.
Old Dec 30, 2012 | 08:35 AM
ou812sm's Avatar
Does anyone know what size the stock camwould be in a 2009 denali 6.2 what size cam should you run in a whipple charged engine boostbia about 10.5 to 11 pounds why would think its at 15 pounds
Old Dec 30, 2012 | 08:39 AM
ou812sm's Avatar
Also plan on running 1.85 yella terra rocker arm which would put in to.58x range of lift
Old Dec 30, 2012 | 08:51 AM
03sierraslt's Avatar
What all do you have done to it already? If you can post up a picture of your engine bay, you have the Whipple with the whipple intercooler right? The reason he thought your boost would be higher is because if you have a On Manifold Whipple, with a 3.0" pulley on a stock 6.2 your boost should be higher.
Old Dec 30, 2012 | 09:33 AM
ou812sm's Avatar
I have the whipple that bolts down to the top engine in place of the intake manifold
Old Dec 30, 2012 | 09:39 AM
ou812sm's Avatar
3.625 pulley equals about 5.5 to6 pounds on 6.2 for each smaller increments of .125 equals about a pound so 3" pulley works out to be about 5 pounds more
