cam for my Whipple
Old Dec 31, 2012 | 03:16 AM
  #21
ou812sm's Avatar
I text roger vinci and told him what I was looking for the cam he spec out for me was 212/224 on lsa114 ground on a aggressive lobe of.324 and for me to 1.8 rocker arms to give a gross lift of .585 which is close to the cam I have found 219 / 229 .550/.550 in a lsa of 114 the major difference between theese two I think is I might have to run a stall converter unless someone can tell or explain the difference of why vinci cam is better
Old Dec 31, 2012 | 01:26 PM
  #22
sand man's Avatar
check out the texas speed ls3 blower cam
Old Dec 31, 2012 | 01:58 PM
  #23
old motorhead's Avatar
I'd go a little bigger if going to all the trouble of a cam swap. I daily drive a 222/230 115 in my 6.0L on the street with stock converter. If serious about quarter mile racing, you would probably want a mild converter with that size or bigger cam. A 218/230 116 would work fine with stock converter street or strip. 222/234 117+2 would be my choice if I wanted a little more, but you might need to fool with a little looser converter. Both of these cams would have a slightly rough idle, but no bad manners if tuned right. Use Comp's LSL lobes and ditch the high ratio rocker arms. Lift is about .600 or a little more with these lobes and 1.7's.
Old Jan 1, 2013 | 08:22 PM
  #24
ou812sm's Avatar
So anyone have anymore thoughts on this cam
lawhitediamante
Aug 12, 2015 12:14 PM
MS3Z
Jul 30, 2015 06:17 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
ou812sm
Jul 18, 2015 01:12 PM
