is this cam gonna be ok for a radix?
#31
Sorry, but for an everyday driver, instant boost that makes your truck jump at the tap of the throttle will get anoying. I would want it to come on a bit smooth at light pedal responses.
The Playboy girls can call me all day long! No problem with that!
Jim
Jim
#33
that sounds great to me. what would be a reasonable guesstimate on hp/tq numbers with my setup in this cold weather. should be pushing 9-10psi with a hefty meth mixture.
#34
#35
Originally Posted by moregrip
I used 8 lbs of boost, HP & TQ looked healthy. 600/600 ish, then subtract 5% program error and 20% driveline loss.
#39
Originally Posted by zippy
The standard Radix injectors are likely going to be too small with that cam. I also forgot that you have a 5.3L, you should be able to see 10psi with that cam and a 2.8" pulley.
