Broken tvs2300 jack shaft!!!
#21
Adkoonerstrator
Is that sucker carbon fiber, looks like it. They use that stuff to make driveshafts so I'd think cf would be ok in this application. Before anyone says it I know there are tons of different variations of cf.
Whatever happened, that sucks, glad they are taking care of it!
#23
#24
#25
I talked to David today, that is certainly not normal. These shafts are tested to far heavier torsional loads that you are putting through it. The CF is used because it has a higher critical speed than the steel or billet shafts. You will be hard pressed to find something that can spin at 15-20K rpm unless you are using CF.
#26
Have you considered that maybe the person you PMed was not available or able to reply? Did you attempt to contact me via PHONE? I can be reached 365 days a year 24 hours a day via phone.
#28
Magnuson customer service has always been unmatched, in or outside of the industry.
The carbon fiber shaft is the way to go, and warranties exist because defects can happen. I agree, more people should understand this.
Not meaning this towards to OP,just in general
