BOV Operation
Old May 9, 2013 | 09:29 AM
  #21
custom 68's Avatar
so back on the open and close of the BOV, mine is wide open at idle. It does work correctly as it opens and closes. I was not worried and figured it was normal until I read this. Maybe I need to change a spring? to keep it closed at idle but opens when I let off the gas with a higher vacuum?
Old May 9, 2013 | 09:42 AM
  #22
Ferocity02's Avatar
Is air coming out of your BOV at idle? If so I wouldn't worry about it. If air is getting sucked in through the BOV at idle, like mine was, I would suggest a heavier spring.
Old May 10, 2013 | 09:50 AM
  #23
custom 68's Avatar
hum I hadn't checked that. Either way I don't have my maf so I should be ok either way.
Old May 13, 2013 | 04:06 PM
  #24
thunderwagen's Avatar
My Tial would crack open at idle with the soft spring but with it being speed density I really didnt have an issue with it. As soon as it got any throttle it would close. I ran it like that for over two years and never had an issue. Like Atomic said I wouldnt go sit in a sand storm and let it idle but under normal conditions you arent going to have a problem.
Old May 20, 2013 | 12:42 PM
  #25
M&M Turbochargers's Avatar
JGS Precision Turbo Wastegates and Bypass Valves
check out "instructions and guides"
we usually adjust ours so they are closed at idle,, and open a little on decel from a little rev
Old May 21, 2013 | 11:49 AM
  #26
slow67's Avatar
Gingervitis Addict
2 port BOV, closed at idle without extra surge.
from JGS Turbo, how to keep the light spring but keep BOV closed at idle.
JordanH
Feb 19, 2019 07:46 AM
Tuckin15s
Sep 23, 2015 09:35 PM
97_ek
Sep 23, 2015 09:16 PM
Albertachevy
Sep 22, 2015 10:28 PM
fortune46x
Sep 16, 2015 08:18 AM
