Borgwarner with tall valve cover
Old Jun 15, 2019 | 08:22 AM
Go5.3tt06's Avatar
Default Borgwarner with tall valve cover
Anyone who running big turbo borgwarner with aftermarket tall valve cover. I got all set up t6 kit from trick. It’s hit oil cap i can’t fill up oil. What other i can do. Can’t change to stock cover because of big valvetrain roller rocker arm yella. How about driver side drill it and ASAP oil fil. It’s hard to find oil fill kit. Can you help me. You
Old Jun 15, 2019 | 09:40 AM
FFDP's Avatar
You can't put the that valve cover on the drivers side?
That would seem easier than drilling and taping it.
Old Jun 15, 2019 | 10:51 AM
Go5.3tt06's Avatar
I could switch to driver side but fill up it would be back of fire wall. I need front one
Old Jun 16, 2019 | 04:14 PM
smokeshow's Avatar
Mod with training wheels
How often are you filling oil? Not necessarily bad to have the oil fill in an inconvenient spot considering how infrequently oil is added...unless you have other problems.
Old Jun 17, 2019 | 06:17 AM
Atomic's Avatar
I have a gauge for that
Pour oil into the driver side head then put the cover on afterward.
Old Jun 17, 2019 | 06:45 AM
03sierraslt's Avatar
I would just swap them from one side to another. I have LS9 covers and with the taller aftermarket heads I just barely have enough room to get the oil cap off. Problem is that there just isn’t much real estate in that area once you have a Large frame T6 in there.
Old Jun 17, 2019 | 08:53 AM
Atomic's Avatar
I used a flange as a spacer at one point
Old Jun 18, 2019 | 11:48 AM
Go5.3tt06's Avatar
as simple I finish order filler bung Ill drill on driver side valve cover and tig it up.
foose04
Apr 27, 2013 07:03 AM
matt//
Nov 11, 2011 06:18 PM
kwk174
Sep 12, 2011 10:38 PM
02_2500avalanche
Apr 14, 2011 10:10 PM
Dark Halo
Feb 20, 2006 03:48 PM
