Boosted guys, what are your I.A.T.'s???
Old Feb 11, 2007 | 01:22 PM
  #31
MikeGyver's Avatar
Originally Posted by trever1t
Hmm, maybe I need to work on my IC setup?
My IATs are over 80* before I even go into boost. How would you suggest I lower them any more, I already have meth
I checked your truck page to see if I could offer any advise as to why your IC setup is not working very well, but I can't find any mention or pictures of it.
Old Feb 11, 2007 | 01:30 PM
  #32
trever1t's Avatar
2nd fastest 5.3 ECSB
I have the stock Magnacharger IC mounted in front of the radiator. Open billet grill shouldn't be restricting air at all.
Old Feb 11, 2007 | 02:04 PM
  #33
James B.'s Avatar
At 6 psi fromt he 1.6L Whipple on the 383 I have logged:
- a maximum of 208 degrees WOT, outside temp was 95.
- cruising is from 30-40 degrees higher than ambient.
I will have some new numbers in a few weeks with the 2.3L Whipple and A2W intercooler.
Old Feb 11, 2007 | 02:13 PM
  #34
nightrunner's Avatar
Mr. Obvious
i believe thats actually the heat exchanger and the intercooler is a bar and plate design in the lower intake manifold
Old Feb 11, 2007 | 05:23 PM
  #35
trever1t's Avatar
Yeah, yeah, that's what i meant
Old Feb 11, 2007 | 06:52 PM
  #36
MikeGyver's Avatar
If you could measure the in and out temperatures of the water going through the heat exchanger, then I'm sure that Magnacharger would be able to tell you if you would benefit from a larger one.
Old Feb 11, 2007 | 08:28 PM
  #37
Stoichiometric's Avatar
I would add a second heat exchanger in series to the first one. In the first, out into the second, then back to the heat source.
Old Feb 11, 2007 | 08:40 PM
  #38
Whooaaa 208! Try not to melt a piston. You need an intercooler.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
