Boosted guys, what are your I.A.T.'s???
Old Oct 22, 2006 | 07:36 PM
ranwalk's Avatar
Default Boosted guys, what are your I.A.T.'s???
Curious to see what kind of IAT's everyone sees. At cruising speed and on WOT runs
Old Oct 22, 2006 | 07:44 PM
fullthrottledan's Avatar
usually about 5-10 over ambient, unless im hammering it, then i see about 20-25 over.
edit: intercooler is a 31x12x3, running 15psi. I havent run my truck in anything over 70 degrees ambient yet either.
Old Oct 22, 2006 | 07:45 PM
dewmanshu's Avatar
Moderately Differentiated
65* Ambient cruise 95* to 105*
WOT in a 1/4mile I ran a 12.7 with ambient at 55*. My IAT start was 100* at the end it was 165*. You can raise the ambient temp to around 70ish and my finish IAT will still be around 165ish. Larger Hxr. After 75* ambient, a wot run will start to warm up some more.
I have a radix, as you know, IAT sensor is in the manifold. Aluminum.
****EDIT***thunder brings up a good point...meth
my #'s are without meth and I am at 9psi.
Old Oct 22, 2006 | 08:04 PM
ranwalk's Avatar
At what level of boost? On a WOT run in 3rd gear, I saw a 34 degree increase. From 68 degrees to 102. Thats at 12-13 psi of boost.
At cruise speed I see 6-10 degrees above outside temp.
Old Oct 22, 2006 | 08:08 PM
thunder550's Avatar
High on diesel fumes
I am usually 30-35* over ambient while cruising, then I can get up to 150-160* on a WOT run with 50/50 water/meth at about 8.5 psi on a 2.8 Radix pulley.
Old Oct 22, 2006 | 08:58 PM
Whippled 496's Avatar
With no intercooler, here is the bad news......
65* ambient @ 7psi cruising i see 155*
65* ambient @7psi WOT in 1/4 mile i see 220*
I will have my intercooler on in a few weeks, i will report back......
Old Oct 22, 2006 | 09:16 PM
dewmanshu's Avatar
where is your IAT sensor? with 68* is it safe to assume the MAF?
Old Oct 22, 2006 | 09:27 PM
TchargedLS1TA's Avatar
Im assuming you're talking supercharger talk.. On my wifes non-intercooled STS, we normally see about 120-130 when cruising and can sometimes peak all the way to 145-150 when the ambient is about mid 90's
Old Oct 22, 2006 | 09:28 PM
MikeGyver's Avatar
If his sensor was in the MAF, the the MAF would have to be downstream of the blower to see an increase in temp. under boost.
Old Oct 22, 2006 | 10:00 PM
dewmanshu's Avatar
DOH! good point!
