Boosted guys with spray step inside
Old Sep 12, 2008 | 09:11 PM
nonnieselman's Avatar
Originally Posted by Spoolin
trever1t is at 75 shot on stock motor and 10 psi
Jonathan is on a 50 shot on stock motor at 6 psi
Dewey is on a 75 shot on stock motor at 11 psi
KYSilverado is on a 75 shot on stock motor at 12 psi
can't think of anyone else right now, looking back some of the boost might be off.
So not only am i running the lowest boost but also the lowest shot....
And its 5psi crackerhead..
Im running my setup on a WOT switch and arm switch.. When i had the vacuum brakes and couldnt get boost off the line i would hold the rpms as high as i could before it started pushing through the front brakes. When it went WOT it would hit.. and hit hard.
i posted up not too long ago about our local 500' track.
7.9@71 2.3 60' on 5psi
7.0@80 2.0 60' on 5psi and 50 shot at 10.8AFR.
Now with hydroboost i can get 4psi by brake boosting it. Goin to see what it will do at the track now. Also should have my 65# injectors so up goes the boost if i can ever get my Wideband working again.
Old Sep 12, 2008 | 09:15 PM
quicksilverado's Avatar
Just curious. Why not just turn the boost up?
Old Sep 12, 2008 | 09:19 PM
My injectors are maxed out and without spray it would take till 3000rpms before i got in full boost.. with the 50 shot i could hit it off the line and it would load the engine up and get full boost as soon as it sprayed.
Now with hydroboost i can get boost off the line so ill see what it will do without spray now..
Old Sep 13, 2008 | 12:09 AM
hemidup's Avatar
In current weather I have 11lbs of boost off the blower and hit it with a 30/30 2 stage. I tried a 50/30, but broke the tires loose on my 4x4 during the launch, but it netted me my best 1.592 60' to date. Colder air is coming soon and my boost should be back at 13.5-14psi. I'm thinking that I'll stick with my 30/30 shot.
Old Sep 13, 2008 | 07:35 AM
KySilverado's Avatar
Maybe someday. But more like a 50 shot, stock motor, @ 9 psi
Old Sep 13, 2008 | 11:24 AM
kbracing96's Avatar
Spoolin is FULL of misinfo, lol
Old Sep 13, 2008 | 07:16 PM
Spoolin's Avatar
GFYS and STFU
LOL...that's what happens when I'm called on for "facts"!
I seriously have the worst memory...I should just keep to myself from now on!!
Old Sep 13, 2008 | 07:25 PM
kbracing96's Avatar
But you tell good stories, right?
Old Sep 13, 2008 | 07:31 PM
Spoolin's Avatar
GFYS and STFU
I don't do alot of things very well!! You ever see my time slips?
Old Sep 13, 2008 | 08:07 PM
charcold-bowtie's Avatar
yeah 14.2 @ 113 mph lmao. Something stupid funny like that.
