Boosted 5.3-6.0 ??
Old Nov 27, 2008 | 05:57 AM
bud8fan's Avatar
Isn't that order backwards?
went from a sts to a radix to a front mount...all completely diffrent animals.
Only downside I see is mileage. See my above comment. I need more evidence. A friend said his 6L swilled gas too.[/QUOTE]
i had the front mount put on the 4.8 along with a new flt5 and yank2600 and was getting 20 mpg on the hiway and then swapped the 4.8 for a 6.0 and still got 19.5 mpg hiway. swapped out the 60e for the 80e and now get 14-16 on the hiway
Old Nov 27, 2008 | 09:53 AM
TURBHOE's Avatar
i get 14-16 as it is. so it seems it may be the 80e in the hd's killing mileage not the displacement.?.
Old Nov 27, 2008 | 11:09 AM
WJ MARK's Avatar
I don't care about the milage that much, just power difference between the 2
Old Nov 27, 2008 | 11:16 AM
sureshot's Avatar
I know my buddy, sharpshooter, used to run a consistent 14.1 in the quarter on his old setup: 5.3 with procharger. When the 5.3 blew we replaced it with an LQ4 and cam, the only thing we did was put the cam in, and he recently ran a 12.8 and consistently runs high 12's-low 13's now. Keep in mind this is on an ecsb with a 6" lift and 33" tires!
Old Nov 27, 2008 | 11:33 AM
BlownChevy's Avatar
blownerator
25 Year Member
I opted to go with the 5.7L in the crew cab . It added the same SOTP gains as the 6.0 did in my last RCSB. The other added feature of the 5.7L is better fuel mileage, I was still able to get 17-18 MPG hwy/street.
Just my .02
Old Nov 27, 2008 | 11:36 AM
fastnblu's Avatar
i had the front mount put on the 4.8 along with a new flt5 and yank2600 and was getting 20 mpg on the hiway and then swapped the 4.8 for a 6.0 and still got 19.5 mpg hiway. swapped out the 60e for the 80e and now get 14-16 on the hiway[/QUOTE]
Ya, but you went from largest cubes 1st to smallest, in that order, correct? You've got to experience something most can't. 3 different power adders. Most might not ever get to try 1. Gives u a perspective most wouldn't have.
That sounds like a 80e kills mileage. How can that be? A 60e has a 3.06 1st whereas a 80e has a 2.48. Did u change to a wild convertor when u put in 80e?
Unless u guys are puttin in 80's, & since u know they're bulletproof, are beatin on them alot harder whereas knowing the weakness(es) of the 60e. Maybe you were takin easier on the 60e. Myself, I just pound on the 60e & hope it holds.
Old Nov 27, 2008 | 11:40 AM
Raffman's Avatar
Power is addictive......You get accustomed fast and want more.
So don't do anything to the 5.3 pass and go directly to FI 6.0 +
Old Nov 27, 2008 | 11:43 AM
sharpshooter's Avatar
couldn't have said it better
feels like a different truck
Old Nov 27, 2008 | 12:56 PM
ForcedTQ's Avatar
Need 6L80E conversion swap now!!!
Old Nov 27, 2008 | 01:10 PM
fastnblu's Avatar
Sounds good to me. How much $?
