Boost vs Pulley Size
Old Mar 30, 2008 | 05:23 PM
Okie5.3's Avatar
Default Boost vs Pulley Size
Ok guys what size pulley comes with a Radix 112 model for a 5.3? Is it a 3.25" How much boost is that supposed to be?
Reason I'm asking is my combo consisting of an LQ9, LS6 cam, stock heads with a 5 angle valve job, full length headers, and a single 3" exhaust with a 3.10" pulley will jump to 6lbs and come back to 5lbs on a run/pull. Does this sound about right?
I am considering dropping to a 3.0 or a 2.9 pulley. Where will that put me for boost? I am thinking it should be about 1lb per .10" smaller, so with a 3.0 ~6-7lb and a 2.9 in the ~7-8lb. Would this be too much boost for a 10.0:1 motor on 91 octane?
Old Mar 30, 2008 | 07:59 PM
Sambo53's Avatar
I'm running the 2.80 pulley and I only see 7-7.5lbs Im just running a stock LQ9 and stock cam. I also run 93 octane and meth.
Old Mar 30, 2008 | 08:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
the 5.3 comes with a 3.4" pulley. Head work and free flowing exhaust will make boost pressure drop but increase horsepower, remember boost is a measure of restriction measured in the intake manifold.
As far as the CR goes you will want to check the tune carefully, maybe consider Meth? My setup makes about 9 peak lbs with 9.9:1 CR.
Old Mar 30, 2008 | 08:44 PM
Okie5.3's Avatar
What pulley are you running? How does your setup compare to mine. The tune is on the conservative side, but pretty much on. The AFR is 11.8-12.0 with 16* timing. With the 3.4 pulley we had timing at 20* AFR 11.8-12.0 with 0 KR. Ed wanted to leave a buffer for reliability and the chance of crap gas. How much will it change the tune if I went to say a 2.9 pulley and meth?
Old Mar 30, 2008 | 09:03 PM
trever1t's Avatar
I'm no tuner so I can't really answer. My AFR is more like 11.4-11.7. Meth will allow you to keep a little more timing than without.
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
