Boost vs Pulley Size
Ok guys what size pulley comes with a Radix 112 model for a 5.3? Is it a 3.25" How much boost is that supposed to be?
Reason I'm asking is my combo consisting of an LQ9, LS6 cam, stock heads with a 5 angle valve job, full length headers, and a single 3" exhaust with a 3.10" pulley will jump to 6lbs and come back to 5lbs on a run/pull. Does this sound about right?
I am considering dropping to a 3.0 or a 2.9 pulley. Where will that put me for boost? I am thinking it should be about 1lb per .10" smaller, so with a 3.0 ~6-7lb and a 2.9 in the ~7-8lb. Would this be too much boost for a 10.0:1 motor on 91 octane?
the 5.3 comes with a 3.4" pulley. Head work and free flowing exhaust will make boost pressure drop but increase horsepower, remember boost is a measure of restriction measured in the intake manifold.
As far as the CR goes you will want to check the tune carefully, maybe consider Meth? My setup makes about 9 peak lbs with 9.9:1 CR.
Stainless Works
13
Nov 5, 2015 03:31 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
