boost spike
Old Aug 30, 2010 | 08:28 PM
bad cutt's Avatar
Default boost spike
i just installed a new wastegate and a manual boost controller. i got the boost about where i want it 13 pounds. but when it shifts it spikes to 16 or 17 pounds. and at high speeds it starts to creep up past 15. ive blown headgaskets before at 18 so is there a good way to control this?
Old Aug 30, 2010 | 08:31 PM
smokeshow's Avatar
Mod with training wheels
What size spring is in the WG? Try opening up the manual boost controller all the way so the WG sees full pressure and see if it spikes still. Like if its an 8psi spring and still spikes to 9 or something. That'll at least narrow down the possible problems.
Old Aug 30, 2010 | 10:16 PM
bad cutt's Avatar
without the boost controller it didnt spike. it would still creep though
Old Aug 30, 2010 | 11:09 PM
smokeshow's Avatar
Well good, you separated the two problems lol. Whats the details on your setup? Engine, turbo, which turbo kit, WG size, etc. Also do you have a pic of where your WG is in your setup? Placement makes a big difference, believe it or not.
I've heard of spikes with manual boost controllers before, though...
Old Aug 30, 2010 | 11:17 PM
Quik's Avatar
5 year bitches!
where is your gate and boost controler referenced from?
what size line are you using to the controller and gate?
is top of gate vented? i know with a electronic you have to apply pressure to top and side of gate to help control boost creep
SS94S10
Jan 3, 2019 01:57 PM
2500ZL1
Sep 12, 2015 03:50 PM
JordanH
Sep 12, 2015 12:02 AM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
