boost regulator of choice ?
Old Nov 24, 2011 | 05:00 PM
rhinosarge's Avatar
Default boost regulator of choice ?
i got a 38mm Tial external wastegate with a 8lb spring inside..
when i get my truck tuned i want to tune it at 12lbs to be safe just in case i do wanna go back to up 12 when riding around the block and a stinking mustang gets on my case !!
so what to buy.. whats popular.. whats good..
turbonetics adjustable boost controller ?
or an electronic controller ..
anyone got some pics .. thanks guys
Old Nov 24, 2011 | 05:59 PM
sprayedenali's Avatar
ams 500
Old Nov 24, 2011 | 07:08 PM
foose04's Avatar
Keep it simple, what I run and one of if not the best manual controllers out there. Hallmans Pro.
Info: Hallman Manual Boost Controllers : BoostController.com LLC - America's Source for High quality turbo boost controllers, silicone hose, and more performance products - 877-836-6155- precision boost control. Turbosmart Warehouse Distributor
Old Nov 24, 2011 | 07:25 PM
rhinosarge's Avatar
what spring should be in my waste gate ? or does it matter
Old Nov 24, 2011 | 07:26 PM
chevrolade's Avatar
hey Foose that pro kit reach the driver dash for cockpit adjusting?i noticed they offer a evolution kit for cockpit
Old Nov 24, 2011 | 09:08 PM
foose04's Avatar
Pro does not, but if you want to be hardcore I'm sure the cockpit version would work. I've seen it installed in Evo's and those guys seem to love them.
Spring in the wastegate will only matter once you max the controller out. Install the controller first, then if you need more swap springs.
Old Nov 28, 2011 | 12:03 PM
slowlsx's Avatar
How many times do turn the **** to get x amount of boost?
I have the cockpit hallman and I turned it half a turn and it did nothing
Old Nov 28, 2011 | 12:10 PM
JankesGTO's Avatar
Really cuz my hallman every half turn is a pound once I get off the spring. Keep turning it till you start gaining.
Old Nov 28, 2011 | 12:39 PM
smokeshow's Avatar
Mod with training wheels
It depends on the spring. My setup spring only makes about 10psi, 5 turns of the HBC gives me 15psi. If your spring makes 5psi, 5 turns would give you 7.5psi. And Josh, the spring needs some amount of preload before it starts doing anything. From fully unscrewed, my controller takes like 2.5 turns before boost goes up.
I just ordered a cockpit control for my HBC, I'll post up some pics when I get it
Old Nov 28, 2011 | 05:31 PM
blue0453's Avatar
Like smokeshow said, keeo turning till you hit that sweet spot. Once that happens I get around 1psi for one full turn. I had to turn it around 4/5 full turns before it started to rise. They are great controllers for the money. My buddy runs around 30psi with his..
