Boost Q's
Old Sep 12, 2011 | 09:22 PM
blwn4.8's Avatar
Default Boost Q's
Whats the difference between boost from a turbo and from a S/C? If any, besides the time it is delivered..
Also, ive been holding up on the 3.0 pulley installation because im afraid of damaging the engine since everyone says to stay under 10 #'s. Right now im at 7-7.5 with the 3.40, do you guys think ill be fine or just stick to the 3.40?
4.8, mods: mp112, 4.10's, Lt's, custom 3" Y, truetrac, 3k stall, and tune
Old Sep 12, 2011 | 09:57 PM
Rick_Vor's Avatar
Boost psi is just a measurement of restriction. It doesn't matter what the source is.
Assuming a stock 4.8l, the compression is around 9.5:1 so you can easily run 10lbs with the right tune. What kind of psi do 4.8's with long tubes see with a 3.0"? Might be better to try a 3.20" and see where you land.
Rick
Old Sep 12, 2011 | 10:22 PM
blwn4.8's Avatar
well it was at 8lb's before the LT's and rear end so i thought it'd drop at least 2lb's so thats why i got the 3.0
Old Sep 13, 2011 | 12:18 AM
blwn4.8's Avatar
anyone else?
Old Sep 13, 2011 | 08:37 AM
joeyc125's Avatar
11 Second Truck Club
Do it if you or your tuner has an idea of what they're doing. I ran 12lbs on my old 5.3. Buddy has a procharged Silvy w/220k miles and 135k of them are w/ blower at 10-12 psi on pump gas.
Old Sep 13, 2011 | 11:02 AM
slow67's Avatar
Gingervitis Addict
A procharger can usually get away with a little more boost than a turbo, as it builds boost based on RPM, and in the upper RPM range detonation is less likely than at peak tq.
Old Sep 13, 2011 | 12:34 PM
black4.8's Avatar
under 10#, what fun is that? i'd say up to 12# is safe w/ good tuning
Old Sep 14, 2011 | 06:36 PM
blwn4.8's Avatar
so dont have to worry about the bottom end giving out or anything?
Old Sep 14, 2011 | 07:06 PM
TimDave217's Avatar
you wont have a problem with the bottom end giving out, like most have said you'd be fine with the 3.0" pulley with the correct tuning. only thing is belt might slip a since the pulley is smaller and belt probably stretched some.
Old Sep 14, 2011 | 07:41 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Swap the 3.0 pulley on there, and get the tune nailed. You'll be happy with the results. Keep an eye on your IAT's, and watch out for KR. Everything else is gravy!
The tune is gonna be more important than ever.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
