Boost a pump?
Old Feb 19, 2012 | 03:26 PM
Boosted_Silverado's Avatar
Default Boost a pump?
im looking at getting a boost a pump for my 04 silverado with returnless fuel system.
i currently have a walbro 255 intank pump installed with 60lb injectors running around 10 psi with a p-1sc
im just wondering when i upgrade to a d-1sc and turn the boost up abit more if this is a good rout to go?
if so what brand boost a pump do you guys recommend?
http://www.kennebell.net/accessories...boostapump.htm
http://www.msdignition.com/Products/...e_Booster.aspx
http://www.raceindustry.com/part-sho...ontroller.html
http://www.easyperformance.com/Flow_...Rev_1G_Web.pdf
Thanks guys.
Old Feb 19, 2012 | 07:22 PM
thinking about ordering the KB BAP.
do i need the 20A or the 40A?
edit. 20A is for a single stock pump and 40A is for a 255 pump or dual pumps.
Old Feb 20, 2012 | 11:06 PM
Blown06's Avatar
8 Second Truck Club
do you have meth?
Old Feb 21, 2012 | 12:48 AM
Originally Posted by Blown06
do you have meth?
no but i plan on getting it.
Old Feb 21, 2012 | 07:54 PM
Chavette's Avatar
I called them a couple of years ago to make sure I was getting the right one for my setup. They have 7 different BAP kits listed and you want to make sure you get the right one for you. I ended up with a 40 amp single for FI setup.
Old Feb 21, 2012 | 07:57 PM
TX Tahoe Z71's Avatar
Running a KB BAP on a stock flex fuel pump and it's keeping up with my 75# injectors on meth, good A/F all the way to 6000rpm (don't have a fp gauge).
Not sure which one I have, but I am guessing it's the 20A.
Old Feb 22, 2012 | 12:41 AM
i got the bap today and got most of it installed.
but where do i hook in for the fuel pump boost wire and fuel pump relay?
Old Feb 22, 2012 | 12:49 AM
Mangled03gmc's Avatar
Baltimore Whore
Nice clean looking set up, but I think I would have just went with another pump inline, on a switch.
Old Feb 22, 2012 | 01:52 AM
10 Second Truck Club
i want a b a p too,let me know how she likes it
Old Feb 22, 2012 | 07:21 AM
Chavette's Avatar
I cut mine into the pump power wire under the Fuse box you mounted the BAP box to.
