Boost my 14 GMC
Old Dec 8, 2015 | 07:20 PM
  #21
ZO6Ted's Avatar
Well we all know many races are won out of the hole especially in the 1/8th which is what I'll run. Do you think it will 60' with a stock converter? It cut a 1.99 stock @ 2300. I would think a blower would push it up a bit.
Old Dec 8, 2015 | 07:23 PM
  #22
ZO6Ted's Avatar
Well I would be buying the kit so I would hope it would be a drop in...better be lol! Yeah he is highly recommended and is familiar with the 6l80.
Old Dec 12, 2015 | 01:19 PM
  #23
ZO6Ted's Avatar
I may order as early as next week if anyone has something to add... I'm all ears!
Old Dec 12, 2015 | 05:10 PM
  #24
thewrx's Avatar
Making 400 to tire on 93 with 33's on 6 lbs tvs1900 stock everything else. Corn ran about 25hp more. I have lt1 pump if i want to turnit up as fuel system pretty close to maxed out on corn fuel. This setup has been on truck since new and now has 45k odo, super conservative timing as this is wifes and ride and the tow rig. Biggest issue is heat so recently got big 5 gal tank, bilge pump, and 2nd pass hx.
Old Dec 13, 2015 | 01:41 AM
  #25
ZO6Ted's Avatar
Thanks for your input!
Old Dec 13, 2015 | 08:45 PM
  #26
Vortec350ss's Avatar
I'm surprosed to hear heat is an issue with such low boost. What pulley is on the truck?
Old Dec 23, 2015 | 04:53 PM
  #27
ZO6Ted's Avatar
Just got off the phone with Brian...2.9 Whipple ordered and paid. Should have it in 10-14 days. Happiness again!
Old Dec 23, 2015 | 05:11 PM
  #28
Old Dec 23, 2015 | 06:48 PM
  #29
moregrip's Avatar
what a rush!
Originally Posted by ZO6Ted
I do like the Whipple but I know I will give up a bit of low end torque. Hoping the 6 spd helps in that regard. It stalls at 2300 right now. Ideally the 1900 is probably a good choice but I'm thinking down the road maybe a 6.2 plus the bigger blower may be easier to resell later? Another question, since we all know satisfaction is temporary, at what level of boost is belt slip a problem with the 6 rib? 10lbs? 12lbs? I wish they offered an 8 rib upgrade as it comes. I would rather start out with what I need anyway.
I had problems with the 6 rib setup at 7lbs of boost and spun my crank damper on the crank shaft at that level as well......but I also knew I was headed for more boost down the road so I pieced together an 8rib setup so it was ready to go when I upgraded from the MP112 to MP122. oh, and pin your crank man!
Old Dec 23, 2015 | 08:05 PM
  #30
BlackGMC's Avatar
Resident Retard
Do they make pulleys for them? I know a few guys ran into issues finding pulleys
