Boost my 14 GMC
Old Nov 16, 2016 | 05:52 PM
  #211
ZO6Ted's Avatar
It actually does. Shocks should arrive shortly and Ill get back to the track. 7's here I come lol!
Old Nov 16, 2016 | 06:07 PM
  #212
07Softail's Avatar
gotta do some headers and a pipe next! Geez those are pretty solid numbers being plugged up by the manifolds.
RT
Old Nov 16, 2016 | 07:02 PM
  #213
ZO6Ted's Avatar
Thank you. It really does need exhaust I guess. I'm just so wary of the summertime underhood heat because of using it to make my living. It gets a workout in Texas summers!
Old Nov 16, 2016 | 08:44 PM
  #214
gonzo 6.2's Avatar
Originally Posted by ZO6Ted
~40-45 hp and 23 tq. Yes on the trans. Gotta be the restrictive manifolds and exhaust. I was quite surprised.
whipple says 7lbs on OEM what gives? Anyone fudging the numbers?
Im now shopping boost gauge
Old Nov 16, 2016 | 09:47 PM
  #215
07Softail's Avatar
Ceramic coating Baby! I coated my D&D Harley pipe and I love it. Wish i didn't get in a rush to install my ARH's or I would have coated them too.
RT
Old Nov 16, 2016 | 09:54 PM
  #216
BlackGMC's Avatar
Resident Retard
So you made less boost after each pull?
Old Nov 16, 2016 | 10:06 PM
  #217
Atomic's Avatar
I have a gauge for that
Pretty common with blowers to that because it gets so hot.
Old Nov 17, 2016 | 10:04 AM
  #218
ZO6Ted's Avatar
Unless my exhaust is more restrictive than the model they tested. Very surprising though.
RT
So the coating helps that much?
Yes. He took timing out as he said it had too much after the stock Whipple pull. It then produced the most on the 2nd pull. Kinda like my track passes. 2nd one was the best.
That's what I figured too...damn heat pumps lol.
Old Nov 17, 2016 | 06:13 PM
  #219
wuznme's Avatar
How was boost read? That's quite a bit higher then what Whipple states.
Old Nov 17, 2016 | 07:14 PM
  #220
07Softail's Avatar
Yes it does work that well and that's with the standard coating. And the stuff that looks like cement spayed in the pipe works even better and it's made for boosted applications Extreme 2000. Like I said I wish I would have taken the time to send mine off and probably will next spring when I can ride my Bike for a week. Jet Hot is all I have used on three applications.
RT
