Boost gauge is in.... Result?!?!
Old Aug 12, 2005 | 04:56 PM
CAMMIN03''s Avatar
Banned
Default Boost gauge is in.... Result?!?!
I finally got around to installing my boost gauge..
At idle it sits around 10hg vacuum..
I didnt get to do a WOT run because its leaking and that explains the 3-4psi at pretty hard throttle...
After I let out of it, it drops to around 8 and then to 11 hg vacuum...
Is this right.. or does it sound right?
Old Aug 12, 2005 | 05:12 PM
camcojb's Avatar
To only have 10" of vacuum at idle you must have a fairly large camshaft. If not, then maybe a kinked boost line to the gauge or it isn't installed in an area that has full manifold vacuum.
I get 14" of vacuum in gear with Stage II cams on my Lightning. 12" in gear with the A/C on. Even with these cams I still show 18-20" of vacuum when I remove my foot from the pedal to coast to a stop.
Where are you hooking the boost gauge to?
Jody
Old Aug 12, 2005 | 05:50 PM
CAMMIN03''s Avatar
Banned
Jody
My cam is 212-218-522-529-114
also I have no cats, or mufflers... and a cutout
Old Aug 12, 2005 | 06:38 PM
ranwalk's Avatar
I just went out and checked mine. I'm running just a hair over 16" vacumn at idle, if I blip the throttle it will go to 20 when then engine idles back down then return to around 16-17 vacumn. This is on a 6.0 with a whipple, little larger cam than you. Some head work, long tubes,no cats, 3inch y-pipe to 3.5 inch single magnaflow dumped.
Where are you hooking up your boost guage line?
Old Aug 12, 2005 | 07:08 PM
CAMMIN03''s Avatar
Banned
Yeah... I think thats the problem....
It said tie into a manifold Vacuum line...
But I talked to YellowSierra and theres a place where the throttle body used tobe where it has a place to hook it up.....
Im goign ot put it there tommorow.... and see if anything changes!!
Old Aug 12, 2005 | 07:44 PM
thunder550's Avatar
High on diesel fumes
My 5.3 with Radix is about the same.
Old Aug 12, 2005 | 09:05 PM
TURBHOE's Avatar
where is the boost leak?? if you have a boost leak it could suck vacuum through there if your boost gauge is before the leak the you won't show as much vacuum.
Old Aug 12, 2005 | 09:35 PM
CAMMIN03''s Avatar
Banned
I am going ot try and put it in the front of the intake manifold, where the supercharger meets it..
and I wil lhave some more results!
Old Aug 12, 2005 | 09:38 PM
TURBHOE's Avatar
cool where is the leak??
Pretty sure mine is around 16-18 at idle.
